Since rewiring my Philips VCR/DVD (Model DVP312ov/7) it responds only to channel 3. How can I reset to channel 4?
  • cdodgerdog Feb 02, 2010
    I guess I didn't clarify the details of my problem. I previously had this VCR/DVD hooked up
    to the same cable box & TV and was working perfectly thru channel 4. (cable box to VCR to TV).
    After removing VCR and attempting to connect to different cable box I decided to place it back in it's origional set-up. I wired it exactly the same way as previous, however, now it will only play on channel 3. My problem is: (1) There is no channel 3/4 switch on unit, and (2) I've lost my owner's manual which may have offered instructions on how to reset to channel 4.
    Is their a standard way to reset thru VCR menu? Where can I get another owner's manual?
    Thanks, cdodgerdog
    President:
  • 1,015 Answers
Try doing this...Press VCR to put the DVD/VCR in VCR mode. The VCR light should be on. Insert a tape and then start the playback. While tape is playing press and hold the play button(VCR side) for approx 3 to 5 seconds. This should switch the output back to channel 4. Repeat this to change it back to channel 3. The VCR is factory set to be on channel 3 so when you unplugged the power it was long enough to change it back to 3. So remember this procedure if the power goes out! Let me know if this works and if you have any other questions.
Posted on Feb 03, 2010
  • muebe Feb 03, 2010
    Also sometimes you may need to hold the VCR button and Play(VCR) at the same time for 3 to 5 seconds to get the channel to change if holding the Play button only does not work.
    And here is a link to an online manual available in PDF format http://download.p4c.philips.com/files/d/...
    This is for the model DVP3150v(they do not have a3120v listed)
  • 1,476 Answers
You haven't meantioned exactly what you rewired or what the hookup is now? I must assume that you are using the cable connection through the tuner in the tv. Check the rear of the dvd/vcr and make sure the wire going to the tv is hooked to the connection marked out or out to tv and the other wire, cable I presume, is connected to the input to the dvd/vcr. If this is all wired as stated there should be a switch on the rear of the unit marked channel 3 (to left) channel 4 (to right). Slide to channel 4 and you should be able to watch the program on channel 4 on the TV. I also just realized you could be talking about the input to the dvd/vcr, it isn't clear which end you are referring to. If that is what you need to know you still need to check the wiring I just talked about. Is there another device ahead of the dvd/vcr such as a cable box? If so it is probably capable of being reset to a different output. That information should be in the owners manual. Usually it requires going into the menu of the device, finding the output selection and changing it to the desired channel. A better way to get the signal to the dvd/vcr would be using the composite output. If you would like to try that let me know and I will try to walk you through it. Let me know how you make out.
hardrocko
Posted on Feb 02, 2010
  • Kim Yearick
    Kim Yearick Feb 07, 2010
    Ok. Let's see. Had it hooked up to a box. Worked ok on 4. Removed then decided to hook back up to same cable box, would not work. My first thought is that when your unit losses power it defaults to channel 3. If you access the menu it should be straightforward how to change the channel to 4. Check this out and get back to me.
    hardrocko
  • Kim Yearick
    I guess something else just occurred to me. Why does it matter whether it plays on channel 3 or channel 4? It should still work with your tv. Does your tv have a problem with channel 3? Let me know.
    hardrocko
How do you change to 3 or 4 channel on tv for it to work?
on the back of the DVD/VCR you will find a little slide switch that will select either chan 3 or 4 for output ... your tv must be set to the same channel.
Jun 24, 2010 | Philips Magnavox DVD/VCR Dual Player
Need to down load the codes i need to use with a dolby dvd player
http://www.p4c.philips.com/files/s/sru3006_27/sru3006_27_dfu_aen.pdf
That is the link to the manual if you need it. All the codes and information is on page 7
Press and hold the SETUP button until the red
indicator stays on, then release the SETUP button.
2. Press and release the desired mode button (TV,
VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
red indicator turns off. For an invalid code, the red
indicator flashes.
4. With your device on, press CHANNEL UP. If the
device responds, no further programming is required.
Note: If some buttons do not operate your equipment,
try one of the other codes for your brand.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the SETUP button until the red
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
May 21, 2010 | Philips SRU3006 Remote Control
The tv is stuck on channel 3 and i want to change the channel and i have no remote. How do i do it? I have a magnavox tv dvd/vcr vcr recorder model 20mc4304/17
This is hard but understandable. If you cannot change it on the frount of the unit with the channel up and down buttons then you may have to get a universal remote there is no solution or quick fix or any type of factory reset unless you had the remote to get into the menu. good luck
Apr 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
No channel below 7 when hooked direct to cable connection. Reset and auto program channels , only get 7 and up. This makes it unable to use VCR tuned to channel 4 or 3 . As well as not getting the lower...
low band in the tuner is bad .the tuner needs replacing. simple way to fix it use vcr or dvd with tuner
in it use video inpiuts on tv and use the tuner in vcr or dvd. works great
bc
Feb 25, 2009 | RCA F32650 32" TV
Magnavox 2205 DVD/VCR Output Channel Control
1: set tv to channel you want your vcr output to be on. 2: turn vcr on (if it is a vcr/dvd combo make sure it is on vcr) 3: put in video tape. 4: press play button one time, release it, and then press and hold it for three to five seconds. i had to call customer support to figure this out on mine.
Jan 17, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
