Question about Vizio L37 Television
I have a new tv, a Vizio model VL370M and there is a humming noise when I am using standard definition. It is present also when I use a DVD player. It is not the cable box. A Vizio repair man put in two new boards but the hum continues. The repairman says it might be the speakers. Can you help? Thanks, B.Nesse
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 54 Answers
You could have a loose screw near one of the speakers. I had this problem and it created a vibrating humming noise, especially when there were high pitch sounds happening.
Posted on Feb 03, 2010
    Genius:
  • 1,011 Answers
If you can handle it then check the 12VDC supply filtration. I mean to say that you have to confirm that the 12VDC is coming with stability and no noise inside it. The filtration work is being performed by the capacitors in the circuitry. Check the capacitor condition in main board please. If it is plague (bad capacitor) then try by replacing it. The sound can be mainly heard through speakers and it most probably caused by sound processing area presents in main board. This kind of thing can be eliminated by changing the main board.
good luck
Posted on Feb 02, 2010
  • SALMAN NASEER Feb 02, 2010
    its the complete block diagram of main board and here are the voltage points
    Concentrate on these diagrams and check accordingly.
    good luck
Can not hook up my dvd to my new vizio tv
What is the brand name and model number to your DVD player?
Jun 07, 2012 | Toshiba Televison & Video
Vizio vl370m remote control
If remotes have been ruled out the only way to test the remote infrared receiver is with the set apart/ and a schematic measure voltage at the receiver when the remote is used---most of the time since the part is rather small this is just replaced to see if it is or is not the problem; some receivers will fail where if the remote is held very close they work--always the receiver in that case.
Apr 12, 2012 | Vizio VL370M LCD TV
Most of the time I switch between inputs on my Vizio the sound turns off. It seems to be related to switching between HD and non HD formats. Is there anything I can do to solve this issue?
Hello.
If sound turns off for a couple of seconds it is actually not an issue but normal operation. When you switching between formats different software protocol is in use and it need some time to synchronize.
In case if sounds turns off and stays off you have to make sure where this problem is originated.
If you have DVD player with both standard and high-definition outputs - connect them both to the different TV inputs and switch to see if problem is still there. If sound comes back while using DVD - you might have problem with your cable/satellite box and TV has nothing to do with it.
If DVD "test run" creates same issue - main board in your TV have to be replaced. Vizio have many software/firmware - related issues.
Regards.
Russ.
Dec 01, 2010 | Vizio 42 in. LCD TV
Can I safely use my new Vizio HDTV on regular cable ?
you may try...and you might surprize if it works then no need of the cable guy...
Dec 31, 2009 | Vizio L37 Television
DVD hockup to 37"VIZIO TV
There is no reason that any video player with RCA video/connections cannot be used with your new TV. However, you will not experience any increase in definition, even if your TV is High Definition.
If you used a Component connection from your DVD player (three cables for Video), all that is required is that your TV have Component cable inputs.
Oct 10, 2009 | Vizio L37 Television
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Aug 26, 2009 | Vizio VW32L 32 in. LCD HDTV
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Vizio vw42lf hdmi problem
The factory menu won't help you diagnose anything. If you are having issues on both HDMI ports, definitely check the cable and that the output works on the DVD player, try this on another TV if possible. If all else fails, call Vizio @ 1-877-MYVIZIO and they will send one of us techs out to replace the main A/V board, that should resolve your problem.
Aug 13, 2008 | Televison & Video
Loud buzzing noise
Out put Capacitor breaking down - needs a serive replacement if available.
Nov 13, 2006 | Sony DVP-NS55P DVD Player
Vizio L37 Television Logo
780 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
