those are both safety features built on every lawn tractor made for past 20 years. every summer they save countless feet, dogs, and grandchildren. lift the seat up, you will find a pressure switch which either opens or closes a circuit when somebody sits in it. take that switch out of the circuit, and you now have a mower which will allow you to put your toes under the running deck when you are not in the seat. you will find a similar switch attached to the reverse gear actuation mechanism. disable that and you are free to back over everything and anything with blades a'spinnin.
dharral4588, Common problem with "cold-cathode-fluorescent-lamp" "backlit" LCD monitors. Read more of my fixya profile and visit the links you will find there. Your unit no different than any other brand!!!!! The good thing is this! Your unit WORKS!! Just not long enough. Unit can be REHABED by you or an electronics technician who knows forward and backwards all there is to know about "switch-mode-power-supply" operation and "CCFL inverter" (electronic ballast) operation and repair of the two most likely causes of LCD monitor failure. READ, READ, READ, before you do anything. Then come back and tell us what you will do to solve your BLACK or BLACK AND BLANK screen problem. Come back and rate this response only after you have done your research and feel that this response has been helpful in your decision making process. Bye for now. 12fixlouie on fixya
the clicking of your selector is telling you that you have a fault but it does'nt tell you what type of fault . It could be anything from not being reset to a control board , or a motor to pump my advice to you would be to call an expert . goodluck
there are two..a mechanical one, and a firmware one..check the panel on your satellite pro, to see IF the wireless is illuminated. if not, find the switch on front or side of unit, and turn that on first.
it is telling you, your machine has a problem you need to tell me what program are you putting it on. if you put it on a spin only and it keep going round What you need to do is turn the machine of and open the door leave the door open and put the machineback on set the program to the spin only and then shut the door press start do touch the machine till its finished that should help Its called a reset. if you have the same problem get back to me and i will help you ok.
