How much rent should i be charging for the use of kitchen
How much rent should i be charging for the use of commercial kitchen in public house for chinese food to include buisness rates gas electric water etc. on the basis they turn over £4000 per wk
  • 291 Answers
This is a tough question to answer without having more detail, but I'll try to cover most cases.
The rent portion would mostly be determined by the going rate for space in the area you are located. Look at square footages and published advertisements in your area and use that as a guideline. Utilities would be easy to determine if you had separate meters for the kitchen, check and see if you do, or check with the utility and see if they can add meters.
If not, then use historical bills to see how much use of the utilities there was during a period when the kitchen wasn't in operation. Make sure that if you do this, you multiply the use (kWh, gallons/liters of water, ...etc.) by the current published rates, don't go by the dollars charged on past bills.
Another way to do this would be just charge a percentage of the monthly revenue. You'd have to check and make sure that you were charging enough to cover the utilities, though. 5% seems a good place to start. This would allow you to profit more if the kitchen had a good month, and since utilities would go up/down as their sales went up/down, it would let you handle not having a separate meter.
Hope this helps, and best wishes!
Posted on Feb 02, 2010
Which is the best stainless steel cookware making company in India?
As we all know Kitchen, the heart of a commercial kitchen needs to be designed suitably,. For a smooth and effective running of your commercial kitchen, the aesthetics and other components need to fall in place. A well designed commercial kitchen must work efficiently and safely. A carefully designed kitchen will lead to future profit of the business. For this you will need reputed stainless steel commercial kitchen manufacturers.
List of top 5 stainless steel commercial kitchen manufacturers. You may consider them for your commercial kitchen needs.
  • JSL Architecture Ltd
  • Arttdinox
  • Chheda Industries
  • Gas In Enterprises
  • Himalayan Equipment Manufacturing Co. (HEMCO)
Here you may trust the largest commercial kitchen suppliers, Jindals to design your commercial kitchen. Hiring them will help you build a kitchen that is safe from all the aspects. Jindal Kitchen Star works for their clients to make their kitchen completely perfect with the best quality of stainless steel. Contact at Commercial Stainless Steel Kitchens
Mar 11, 2016 | Home
What is the operating presesure and temperature for a r-134 commercial refrigerator
Those units are going to give you pressures corresponding to the surrounding area. A hot kitchen will get the head pressure up around 150-170 psi sometimes. The suction is going to be somewhere around 20psi give or take 10 psi either way. You can't trust pressure readings except for an indication that the compressor is pumping and you don't have a deep vacuum from a lost charge or plugged cap tube or blocked metering device. Always weigh the charge into the system. You cant be a hack hvac guy and help a guy by putting gas in his refrigerator. Commercial refrigerators are pretty touchy and don;t like to shut off if they don't have an exact charge. Don't take my word for it call True in St Louis they made the thing. Hope this helps and good luck.
Sep 17, 2014 | True T-49 Side by Side Refrigerator...
Year built
Your title deeds should show you the year it was built. Otherwise there is some good advice on this page.
http://www.landregistry.gov.uk/public/faqs/can-you-tell-me-how-old-my-house-is
Aug 20, 2014 | Dishwashers
Can anyone help me to find the best Public Relations agency?
I have suggest you the best service provider for public relations in US. This agency offers best service in Public Relations for more you know about this check this link written below. http://www.imagemarketingconsultants.com/services/public-relations
Apr 15, 2013 | Retail Supplies
How to turn on oven?
mam please check the gas line is open and if the unit is idle for long time the gas line may choked so first you check the gas line.
Sep 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
Garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Dec 19, 2007 | Garland H283 Gas Kitchen Range
k24674
jasbo
jasbo
