Question about Bosch Axxis WFL 2060 Front Load Washer
Plugged in, absolutely dead. Never used but 2 years old
  • Bosch Master
  • 3,463 Answers
I assume you have got the correct size fuse in the plug, which should be a 13 amp fuse.
Ty it in a socket that you definately know is o/k.
Remove top cover, and check for voltage at terminal block with a test meter or test probe.
If still no joy, then could be faulty door lock or control module.
Posted on Feb 02, 2010
My portable rca dvd player will only keep a charge when plugged in
-Battery is too old. All charge able battery last only 2-3 year or maybe even less than that depend on how you use.
-If just a little low and keep charging then it life is short.
-If let it fully empty (dead) before charge the it last longer.
Good luck
Mai
Oct 04, 2016 | RCA DRC6309 9 in. Portable DVD Player with...
Why has my Nokia 800 suddenly gone dead?
try holding the power key for over 10 secs. this simulates a "battery pull". try restarting after that. im assuming you are not out of juice and have tried some stuff there already.
Jul 20, 2014 | Nokia Lumia 800
Motherboard 8i945ae
If intel mo bo make sure that the secondary power line is connected - it will not boot without it. If all is connected properly and nada works then your cmos is corrupted. And that bites!!!!!!!
Aug 27, 2017 | Computers & Internet
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
One and a half years old...dead...won't do a thing. Plug in works. The microwave made a noise and went dead. No keypad, no fan, no light...absolutely nothing.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 09, 2011 | GE Profile Spacemaker Over-the-Range...
Battery is dead
That's a typical problem with most the 1,5 years old laptops. We use them always on main power and the battery goes to dead. If you want to use it on battery change it....
Stelios.
Feb 21, 2010 | Computers & Internet
Battery goes dead after a couple days. was told it could be anti-lock break module...how hard and expensive are these to replace
Your battery going dead every couple days has absolutly nothing to do with your anti-lock break module. (unless it is causing a short or something and staying on-which i doubt.) Have you ever thought that maybe the battery may be dead and old and need replacing. you should test to see how strong the battery is first with a volt meter or load tester. batterys go dead all the time- more so this time of year where it starts to get cold out. If your battery is new or just got it. (usuaslly 2 or 3 years you should be fine). - it may be your alternator isnt charging the battery anymore. Make sure all dome lights are off when the doors are closed. or that nothing else is left on
Dec 02, 2009 | 2003 GMC Sierra 1500
Monitor only displays white screen with color bars running vertically
sounds like it is bad. really no cheap way. get a new one.
May 02, 2009 | Computers & Internet
Changed the gears in my garage door opener: now its dead
RE READ THE INSTRUCTIONS VERY CAREFULLY AND MAKE SURE EVERY STEP WAS DONE IN ORDER.
YOU MAY HAVE A BAD CIRCUIT BOARD - WAS EVERYTHING NORMAL BEFORE THE GEAR STRIPPED?
Apr 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Bosch Axxis WFL 2060 Front Load Washer Logo
94 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
