Question about Kitchen Ranges
My bake coil is not getting hot (turning red) at any temp. The broil coil works and so does everything else.
  • 80 Answers
You nedd new glow coil
Posted on Feb 05, 2010
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
Top element doesn't get red hot on bake but does on broil is my controler bad
The top element (broil element) will come on when you put it in bake only to help the oven temp get to the desired setting. If your temperature is reaching the right degrees you shouldn't have a problem.
Nov 02, 2010 | Kenmore Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Sep 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
The control panel on my gas range does not work the light clock works the stove works but the bake and broil does not i cant get the oven to start and it is not self cleaning but it has a lock button it...
IF ,WHEN YOU SELECT BAKE ,DOES THE BAKE COIL GLOW RED??????? IF YES IS CORRECT, THAN REPLACE THE BAKE COIL(IGNITER).SAME FOLLOWS FOR BROIL. PLEASE RATE THIS!!!
Jun 06, 2008 | Whirlpool Kitchen Ranges
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
