Question about Optoma MovieTime DV10 Multimedia Projector
Shuts down .
Runs 4 about 2 mins then shuts down, has brand new bulb. has no air filters,blew out w/ can of air.
  • Nyssanyc Mar 23, 2008
    I have used this projector only a few times and I now have the same problem. No mishandling, new lamp, etc. And it starts up again relatively soon, so I don't think the issue is overheating. Any other solutions? And how *do* I take it apart to see what's going on inside?
  • Invol Apr 23, 2008
    I also have the exact same problem and Optoma isn't any help at all.
  • 27 Answers
Are fans running
is lamp thermistor positioned too close to lamp
is pj going into shutdown because its not seeing an input signal??? check menus to see.
Posted on Feb 26, 2008
Enigma SLR61-GW. System runs for about 30 mins and then shuts down and a status light blinks 4 times.
Open the front end of the blower.
You will find tow filters that slide out.
Clean them with water and replays them.
Go to the outside one, take a hosepipe and run a strong stream of water thru the radiator until its clean.
This will solve your problem.
Good luck.
Oct 23, 2015 | Heating & Cooling
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Crastman LT2000 - Runs for 6 min. then stalls, restarts after cool down, why?
check the vent on the gas cap if the vent is plugged it will not flow (think of putting your finger on a straw in a glass and lift it up)
Jun 28, 2012 | Craftsman Garden
Starting mac 3227 trimmer
As you have done most things, i would suggest you have a massive air leak, either through the cylinder or crankcase gasket, or through the crank seal, i think its time to pull the whole engine down and replace these items.
May 29, 2012 | Garden
Mower start fine. Runs for 20 min or so and then runs ruff and shuts down. Restarts fine and shuts down appr. 5 mins later. Has new spark plug,air filter, fuel filter and more than enough gas.
It's one of two things. My first thought is that you have a clogged gas cap. Try loosening it when the mower starts to run ruff. If it smooths out again and runs fine, then you know that the carburetor is not venting properly. Either buy a new gas cap or clear the breathing holes in the cap, if possible.
The only other thing it can be is that your Ignition Coil is going bad. A bad Coil, once it gets hot, will shut down. But it usually takes longer than 5 minutes for them to cool down well enough to start back up.
My Vote is the cap!
Good Luck!
Jim
Aug 18, 2011 | Poulan Garden
Turns on and runs for 2minutes and shuts off
Hi, Did you buy it new? How many hours does it have on it. I have a Sharp projector for which I bought a used bulb which started for 1 - 2 mins then shut off. Restarted a minute later then shut off again. I bought a new bulb and that solved the problem. It could also be a weak ballast if the bulb has low hours or if the filters are dirty, it could overheat and shut off. Make sure the filters are clean and the cooling fans are running and the unit has good ventilation.
Hope this helps,
Feb 19, 2011 | Radio Shack Cinego D-1000 Multimedia...
My Sony VPLHS-20 has original bulb, now just shut off 50 mins into the SuperBowl. No fault light, in fact, no lights showing on the display at all. Bulb has around 1800 hours. I waited 10 minute, red...
Pretty sure it the bulb as most are rated at 2000 hours; but also check for full air flow - clean filters etc. Bulbs can run hotter as they age, so air flow is more important, because there is an inside heat sensor that will shut the machine down.
Feb 09, 2011 | Sony VPL-HS20 Multimedia Projector
NP310 NEC Projector shuts down after about 15 min.
Check for good air flow: that filters are clean and the fans are running and not blocked. Check the bulb hours - it may be nearing the end of its life expectancy. If heat is the problem, the inside temperature sensor will shut down the machine or it may be faulty. Inside electronics would be the next suspect.
Feb 07, 2011 | NEC NP61 DLP Projector
Will not run unless gas is full in the tank when gas goes down about 1/4 tank the it shuts down. Fill it back up and it starts and runs. This is brand new used for the first time had to keep filling up...
It definitely sounds like the fuel line in the tank is sticking up, not laying on the bottom attatched to the filter as it should. See if you can drain the tank and take a look inside at the fuel supply line.
Nov 30, 2010 | Echo Garden
I left my infocus x3 on ovrnight wnet down this morning it was shut down when i start it up fans and everything work normal but the bulb doesn't on and it is a fairly new bulb it have had the x3 for about...
it's not recomended to run constant for a day or longer. it may have overheated the lamp. especially if you've never cleaned it out before. take canned air and blow out any dust. but first remove the lamp and see if there is dust blocking the side vent. if there is a lot, the lamp overheated and prematurely blew.
Oct 30, 2009 | InFocus X1 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
262 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
