No oil to the bar and chain
Oil System Plugged.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Displays all components and can be used as disassembly guide:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
As you requested
This is clutch removal (yours is similar):
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
Lou
Parts and a diagram can be seen here:
http://www.partstree.com/parts/?lc=Husqvarna&mn=455+Rancher+%282005-01%29
Hope this helps,
Dan
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
SOURCE: chain oiler
Saw dust has clogged the passage way in the bar. take the bar and chain off and clean the groove where the chain runs, also near where the bar mounts to the saw there are holes in the groove that intersect with cross holes in the center of the bar, push a paperclip through top and bottom.
If this works for you please leave a rating, thanks
SOURCE: location of bar oiler adjustment screw on p4018wt
THIS WORKED FOR ME....I have a 2014. I've had that problem for quite awhile. I finally decided to try to fix it. I took the bar and chain off, removed all the crud in there. Then I took a small air compressor and blew out the entire area so it was pretty clean. I started the saw at this point and gunned it some. The oil became noticible within a few seconds where it comes out at, above the outer chain bar bolt. Once I found the hole, I then drained the oil tank, and then using the air pump, blew out the hole from the blade area to the tank, leaving the oil cap OFF. Upon refilling the oil tank with a lighter oil (10 wt), I restarted the saw, and the flow was really coming. After the oil; tank empties, I'll start using the regular bar-and-chain oil again, but it's pretty heavy, even though it says it is 30 wt.
JimBo
SOURCE: 455 rancher will not oil, replaced complete oiler,
An IPL with oiler components and part numbers can be here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Our job is to provide the knowledge and illustrations available to help you determine which oiler component has likely failed. Your job is to apply that knowledge and make the final determination. If you aren’t comfortable doing that then your only option short of saw disposal is your friendly local chainsaw seller/mechanic. You might be pleasantly surprised at how reasonable they are.
Oil System Plugged.
Lou
