Question about Refrigerators
Freezer not working, while fridge is cold
My freezer is not keeping things frozen, while the fridge is working just fine, any suggestions?
  • jenn_yates Feb 05, 2010
    It is a Frigidaire, I don't know the model number it has to be at least 10-15 years old.
    I know this isn't a lot to go on.
    It seems that the fridge part was working very well almost too cold, yet the freezer works sporadically. For the freezer it is set to it's coldest setting but it doesn't seem to keep frozen.
    Any help would be appreciated before I kick it to the curb.
  • John Hall May 11, 2010
    Make and model number and approx. age ?????
    President:
  • 1,218 Answers
Good day,
If the fan in the freezer seems to run properly, and blows decent air, then you are probably looking at a compressor issue.
That particular age and model, were known to have both compressor problems, and system leaks..Both pricey items if not impossible.
If your looking for something quick and inexpensive, I don't think so.
A service call by a good tech, can confirm that. It has to be your choice.
Posted on Feb 05, 2010
    Sergeant:
    Champion:
  • 263 Answers
In most units the fridge 100% depends on the freezer. Sound like you have a defrost system problem. Need more details.
refrigerator repair in Orange County, CA
4 Suggested Answers
  • 400 Answers
SOURCE: fridge not cold freezer is fine
Your defrost element is faulty, this is attached to the bottom of the freezer coils and also has a defrost limiting thermodisc which should be replaced at the same time. You are getting a freeze up and therefore no air circulation. Also check that the fanmotor is ok.
Posted on Mar 05, 2009
  • 19 Answers
SOURCE: Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Posted on Aug 27, 2009
toolkits
  • 1099 Answers
SOURCE: freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
Posted on Jul 28, 2010
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Westinghouse RJ275M 194l fridge with top 81l freezer doesn't keep the fridge cold anymore. Freezer is fine. is it the thermostat?
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
Nov 25, 2010 | Westinghouse Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Aug 27, 2009 | Refrigerators
Freezer working well fridge not working at all
there is a fan in the back of the freezer that pushes air into the fridge side of the fridge it sounds like this has gone out on you. this fan is usually right by the coils in the freezer the only thing that keeps the fridge cold is a little air being pushed over there constantly
Apr 27, 2009 | Refrigerators
Fridge not cold freezer is fine
Mar 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works refrig part does not
You will probably have to completely defrost fridge, overnight. The air duct between the freezer and the fridge is probably frozen.
Jan 18, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge not working
sounds like the defrost system is defective, frozen. possibilities are fan in freezer wuit or defrost heater open or defrost timer bad. try these first, if not fixed call.
Mar 28, 2008 | Refrigerators
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
