Hi i have a zanussi zwf1621w the drum keeps sticking and makeing a grating noise i think there maybe something stuck inbetween the drum and caseing or the bearings are jamming there is no play on the drum eg up down side to side how do i check the bearings? and is the drum unit sealed to? i want to see if anything is jamming the drum i have took the door seal of and the bottom hose and carnt see anything any help would be grate
  • 139 Answers
SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Posted on Oct 10, 2006
  • 1462 Answers
SOURCE: the door seal needs changing
not too bad a job. remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery. to fit new seal lubricate the slot which fits over the tub with washing-up fluid - essential! starting at the top, press the seal so the flange of the tub enters the slot on the seal. work your way round the using thumbs to force the slot on the tub flange - easy when you have done it once but hard the first time. when slot is on the flange all way round, fit the spring which holds it on.the spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands. fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring. test for leaks before using in earnest. use rinse to test as the water level is higher
Posted on Mar 27, 2007
SOURCE: Replacement door seal/gasket
Replace a tub seal for a frigiduare front loader
Posted on Apr 08, 2007
SOURCE: Zanussi FJS1197 w ashing machine making knocking noises when spinning
I posted the question originally. Are you sure the back panel of the machine doesn't have to come off ??
How about the front ? What tools will be required
Posted on Jan 03, 2008
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
I had someone out today to try repair my zanussi jet system washing machine as it wouldn't spin, the engineer said that is something stuck between the drum and liner and he can not repair it
Not a very good engineer, so I that has suggest you contact another more reputable one. It is a case of removing the rubber seal between the drum and liner and fishing around inside if that is the case. Can you manually spin the drum in either direction? If it moves freely then there is nothing stuck in there and it may be the actual machine program or spin activation at fault.. If it moves in only one direction can you hear something catching? In which case he may well be right. My guess would be that it is an underwire from a brassiere.
Nov 10, 2015 | Zanussi Washing Machines
Hi I have a washer dryer aeg l12710 vit here there is something making noise when machine is on spin, I think there is something stuck in the drum how can I access the drum to remove this
my wife left her chapstick in her pocket which was making noise on the spin cycle. I pulled back on the seal around the drum and was able to remove it. good luck
Aug 14, 2013 | Washing Machines
Foreign object stuck between drum and casing
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
We have a Zanussi model ZWF1621W washing machine and a piece of bra bone(wire) has gone through the holes in the drum and is stuck and rotating with the drum against the drum outer body how do we get it...
DONT RELEASE SEAL. Tilt machine and remove sump hose get someone to rotate drum in hope you can catch hold of wire. be careful of fingers on drum as they are like cheese grater. good luck this is best way and a little patience will do the job
Feb 12, 2010 | Zanussi ZWF1630 Front Load Washer
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
Making a grating noisewhen opperating. maybe pump?
If the noise is only apparent when draining, then it is the pump, if it is there all the time, then it is something else that is causing the prob.
Please rate my solution.
Thanks.
Aug 15, 2009 | Zanussi Washing Machines
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
My WD440 has trown its drive belt and something
hi
it sounds like there is a sock or something simular stuck between the drum and tank,the paddle is removable which may help you hook out the item,if you grab the drum paddle from the rear and pull it towards you it will then lift up,once you have removed the offending item,you just line up the slots on the drum with the pegs on the paddle and push towards the rear of the machine and you will here a click,this means the paddle is secure.
Aug 02, 2009 | Hotpoint Aquarius WD63 Front Load...
Hi.. hope you can help me.. I have a year old Zanussi ZWF1221W - my dear daughter put in a wash without emptying her pockets and something (a hairgrip or bra support) is now stuck between the drum and the...
It sounds like it's actually stuck between the bottom of the agitator and the basket (assuming you've got an agitator). The top of the agitator is usually for bleach or maybe it's fabric softener. Pop off the top (like the lid off of a can) and that should expose a nut or bolt in the center of the agitator. Remove this bolt (make note of how tight it was just after you've broken it free) and lift to remove the agitator. Remove any foreign objects and feel free to clean up anything else down there. Replace the agitator and tighten the bolt approx as tight as it was when you removed it (be careful not to overtighten). Snap on the top of the agitator and you should be good to go.
Mar 18, 2008 | Washing Machines
I hear a loud vibration at the end of the drain cycle
the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
Oct 22, 2007 | Frigidaire 24 in. FDBB945DC Stainless...
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
