Question about Timex Expedition 84601 Wristwatch
I've got the back cover off....how do you remove the inner cover to get to the battery?
  • 2,334 Answers
If there are screws holding the contact - just unscrew them. If there are no screws - contact legs are clipped and you have to undo them by bending them off the hooks. Rate me, plz.
Posted on Feb 02, 2010
Where i can replace the battery of my Casio watch,.Casio hunting timer AMW 705
The battery of my Casio 1846 W-71 was dead, so I tried to replace the battery by myself.
First, you need to get a hand on a CR2016 3-volts battery. It could cost you 5$ or 10$, but I got 5 of them for 1.50$ at an electronics discount store...
Get a precision screwdriver, remove the 4 screws. Be careful when you remove the cover, there's a tiny spring. Remember where it is, then remove it. Remove the watch from the shell.
Using a flat mini screwdriver, remove the cover that holds the battery. You'll need to unclip all 4 corners. There are centers to unclip too, not sure if there was 2 or 4 of them.
Remove the battery, place the new one. Clip the battery cover back, and put the watch back in the shell.
I closed the cover. The watch was showing time, buttons were working, but no sound at all. Looked on the Internet, and read that you need to short circuit it.
Look carefully, there is a label "AC" near a small hole. (Inside the hole you'll see the gray spike of a welding). Just touch something metal inside the hole (e.g. the welding spike) and then touch the positive (top) side of the battery. Put the cover back in place, press a button and listen for the beep.
Screw the cover back in place.
Aug 23, 2013 | Watches
Blank screen with a line. Why?
I have the same, assume the watch battery is gone. Handbook says the whole timer has to go to a dealer to replace the battery.. the printer batteries are easily replacable, I wonder why they made the watch battery such a costly deal?
Sep 06, 2011 | Seiko S149 Stopwatch/Printer
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    How do you replace the battery in a ironman triathlon sleek digital watch
    Thank you for contacting FIxYa.
    Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
  • Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • OR take to a professional jewelry store/watchmaker.
    Good luck.
    Aug 21, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    I got the cover off my Coleman 40-727 wrist watch. I tried to slip the battery cover off as the previous expert suggested. Easier said than done. I was not able to slide the cover off. There appear to...
    You can slide a thin metal strip(like a paper cutter or something) and lift the back cover of the case..Watches do not have clips. It just clicks into place thats all.
    Jul 06, 2010 | Watches
    How do you remove the movement and dust cover
    is there a stem and if so it needs to be removed, there will be a small hole by the crown on hte movment with and arrow pointing to it (most of hte time the arrow is there) push a small screw driver or nail down the whole and then pull the crown the movmemt should fall out, the cover might be part of hte movment, if not should just lift off, let me know if need futher assistance. please rate my answer
    Nov 23, 2009 | Watches
    I have a casio a158w alarm chrono, the screen went blank, opening up the back, is the battery the big round thing in the middle that seems to be stuck in place??? it takes up most of the inner works of the...
    Yes, the big, round thing in the middle is the battery. To get it out you need to unclip or unscrew the contact covering it. When the contact is off you will see the battery number written on battery - buy exactly the same one and replace. After replacement you will need to set the watch manually.
    Jul 09, 2009 | Casio DW290 1V Classic Alarm Chronograph...
    Timex Expedition 84601 Wristwatch Logo
    94 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
