My ariston avxl 105 will not run program cycle. How do i reset it in order to put in the program that i want?
    Brigadier General:
  • 3,917 Answers
Hi
Please check the usefull link for your answer.I hope you will be helpfull.
http://www.user-guides.co.uk/cddownload/Ariston/AristonAVXXL149EX/Ariston-AVXXL149EX-English-User-Guide-Owners-Instruction-Manual-PDF-English-161934.html
Thanks for contacting fixya.com
Posted on Feb 02, 2010
I am looking for user manual for washer maskin ariston AVXL 125
This should do it.
http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html Ariston AVXL 105 Manuals
Sep 02, 2015 | Ariston Technologies Washing Machines
Hi there I need the manual for AUXL105
Do you mean the Ariston AVXL 105? Manual Lib has the manual here: http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html . The English part of the manual starts on page 13. The section on the programs is on page 18.
I hope this helps.
(The link: http://www.manualslib.com/manual/644893/Ariston-Aml-119.html#product-AVXL%20105 has the link to download the manual.)
Mar 02, 2015 | Washing Machines
Ariston avxl 140
Check that you don't overload the machine. This can happen if the load is too heavy.
Jan 31, 2014 | Washing Machines
Ariston AVXL 129 4H lit up and not starting
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line.
May 02, 2013 | Washing Machines
Al1080 reset ariston
Jan 17, 2013 | Ariston Technologies Washing Machines
Ariston avxl 129 washing machine has stopped working.
This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
1st. Suspect is the mother board followed by the motor.
Nov 20, 2011 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Washing machine programme knob has been pushed into machine
Turn the D Shaped spindle with a pair of grips until your machine will do a spin cycle only .
When it can do that put the knob on the shaft with the marker on the knob pointing to the mark on the facia saying Spin
Jun 05, 2009 | Washing Machines
Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Jun 26, 2008 | Washing Machines
Washing Machines Logo
466 people viewed this question
Top Washing Machines Experts
