Question about Dayton Dryers
Have a dayton 8YJ20A.Can't find any info on it.There is a start cap and a run cap.Wire numbers are 7,8 and 9 with a jumper from the start cap to the run cap.Any wiring diagrams?
2 Suggested Answers
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Posted on Oct 21, 2010
Need the size of the run start capacitor for a Dayton 1/2 HP motor #5K529A. Also where can I get one along with the cap cover for the motor and a key for the shaft?
all those items you can easily obtain right from the Home of Dayton , ( Grainger.com) as Dayton is there stock brand
and with there huge system of local stores too , im betting there's one within a short ride to it near you .
Oct 26, 2015 | Dayton Dryers
I have a Dayton 5X848N relay switch that needs connected to a well pump. how is it wired
go to www.ehow.com and type in the search box
"relay switch wiring"
and you will pull up 6 web pages of click on the post articles
on how to wire in a relay. somewheres in all that techinical info
someone will be writing about a relay just like yours & be giving step by step instruction as well as tools needed to do job.
try typing in search box---" how to wire dayton 5x848n relay into well pump.
You should also have the make and model of the well pump handy on paper as you will need this to find out where relay goes to pump motor.
If you need more specific info type in search box
*how 2 wire dayton 5x848n relay into make & model well pump*
try that on google.com.;bing.com;ask.com;yahoo.com as well as
ehow.com
they all have search box on upper right coner of web page & they all answer questions with pre writen info.
Oct 12, 2013 | Dayton Dryers
I have motor dayton model 9ncg4 now the wire is110 conected i need to conected 220 i need the diagram
I reversed start winding to reverse motor now it runs the right direction but it keeps starting instead of running smooth
Sep 27, 2012 | Dayton Wire Wheels Motor 2 HP 3450 230 V...
Dayton motor, 1/3HP, D/D Blower will not star without a spin by hand. Run fine once started, but must have the spin again to start. Is there a stadt capacitor and where ?
The cap is either external or under the bump on the side of the motor... but yeah, that is what is wrong, the cap went bad...
heatman101
Aug 18, 2010 | Dayton Permanent Split Capacitor Motor Fan
Install a new Dayton fan andI don't know what wire goes to what
Brown and grrey brown strip go to seperate capacitor. but you can tale off the gray/brown and use it by putting it on the capacitor where the other wire come off. Russ
Jul 31, 2009 | Heating & Cooling
Need wiring info on DAYTON 3E342A. All info needed .
if you will google the make and model number you should find a pdf owners/ service manual
Dec 17, 2008 | Dayton Electric Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Dryers Logo
104 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
