Question about Thermador Kitchen Ranges
I have a Thermador gas hob on model PRSE304 and need to replace spark plugs. I have obtained Bosch Ignition Head part 189324 but these are too fat and too short. The cooker is over 12 years old so maybe they changed the part. Could you advise?
  • rodspringett Feb 02, 2010
    Thanks for that but my problem isn't knowing how to replace parts but knowing where to get the correct part. I am told that Bosch Ignition Head part 189324 replaced an earlier no. 20.02.377. Maybe this is what I am looking for!
    My problem is sourcing the correct igniter head for this cooker
  • 506 Answers
You need the Bosch AP2838563 ignition plug assembly. Call these people to see if it is on back order and when it can ship. It is $16.67. It is item number 40 on the page. Here is the site.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232959
Look it over and let me know if this helps. Good luck!
Posted on Feb 02, 2010
    Brigadier General:
  • 3,917 Answers
Hi
For replacing igniter( spark plugs) you neeed to order the new part for which you need the hob/oven number which might be on a sticker label on the side of the oven or inside a drawer. The model number is also required which is on the hob/oven or instruction book. Contact the spares department of your hob/oven manufacturer and buy the spare parts. Now switch off the gas and electricity to your hob/oven, and slowly note how the hob igniter ( spark plugs)comes away from the unit. Unscrew the top and it folds upwards revealing the innwards. Your igniter unit may require you to unplug the existing unit and plug in the new unit. Be sure to make a note of how the hob comes apart so that you can fix it together again.
Thanks for contacting fixya.com
Have a thermador psc364gdzs the spark does not work for the gridle
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
Aug 29, 2017 | Thermador Cooktops
How do I replace spark igniter on my thermador oven
what is the model number? there are too many models to be generic in an answer for you. Most Thermador gas OVENS use glo-bar type ignition.Are you speaking of the top burner igniters? you have too many parameters open here for anyone to give a proper answer to you.
Jan 19, 2015 | Thermador Ovens
2 RRIGHT BURNERS DON'T IGNITE
first replace spark plug ,if u get no spark isolate ground wire off the ignition coil then test for spark if not coil needs replacement if u do get spark after wire removal the u need to check oil level and or on/off switch for possible short to ground from sensor or wire
Dec 27, 2013 | Garden
Need discontinued burner valve for GCV36G
You can try an appliance parts supplier. There might be a crossover to a current part
May 08, 2013 | Thermador Kitchen Ranges
I have a Thermador SGCS204R cooktop. The rear
Well first you need to verify that it is getting proper gas pressure to that burner. Try lighting the burner manually with a match. Does the burner look normal? If the burner flame is really small then you will need to remove the burner head and check the orfice for a restriction. If it looks normal then it probably is a weak spark from the igniter, igniter electrode is out of position, or burner head has dirty ports at electrode causing no ignition. Inspect the burner head. If it is removable then take it off and clean out the burner ports(eyes) with a sewing needle. If it is not easily removable then try doing this while it is still installed on the range. Also try using a wire brush on the electrode to clean any carbon/debris build-up casuing a weak spark. You can also try bending the electrode slightly with a flatblade screwdriver(be careful don't break the elctrode) away from the burner creating a larger spark.
Jan 16, 2010 | Ovens
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Kitchen Ranges Logo
204 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
