Question about Kodak EasyShare P880 Digital Camera
It reads internal memory but not a memory card
    Brigadier General:
  • 11,967 Answers
Download the pics from the internal memory if you want to save them. Then: 1. With the memory card out of the camera, go into the menu and find "format"...follow the on-screen instructions. 2. Go into the menu and find "reset"...follow the on-screen instructions. 3. Making sure the slide switch on the side of the card is in the unlocked position, insert the card. Everything should work now.
Posted on Feb 02, 2010
Will not accept memory Card
try a new one and if that doesn't work ask for your money back
Mar 21, 2014 | Kodak C195 Digital Camera
When i turn on my s5700 there is a message (images recorded to internal memory) then on the screen is a white box with black letters (in) i have done what the manual said and formated but it has not made...
Okay "normally" when the memory card is installed the camera reverts back to the memory card from the internal memory. Two things might be happening here one the internal memory needs to be downloaded to the memory card then saved to the computer and the internal memory card formatted. then the memory card formatted to clear those pictures. And or there is a setting switch in menu or set up that you need to manually switch from internal memory to memory card.
I know when I read this over it made scents so you might need to read it a few times to get the idea of what I'm telling you needs to be done
Apr 19, 2011 | Fuji FinePix S5700 Digital Camera
Fuji 45fd -- internal memory full. How do I
It should read the card as soon as you insert it.
Mar 26, 2010 | Kodak EasyShare C613 Digital Camera
My camera doesn`t read memory card.I tried with 2
On most cameras, once you start to use the internal memory, the camera doesn't want to read a memory card. You need to go into the menu and "reset" the camera. Then, with no card in the camera, go into the menu and "format" the internal memory. Then, insert the card and "format" it. This will erase it so download any pics first.
Mar 01, 2010 | Pentax Optio M20 Digital Camera
Our C613 is not reading the memory card when it is turned on. It goes straight to built in memory which only holds 12 pictures. What do we need to do??
Pls. check that the "lever" on the memory card isn't set to black the reading of the card.
Go into Menu, Cam settings and AUTO or internal: Press OK for Internal.
NOTE if the cam. cannot read the card it will automaticly go over to internal memory.
Good luck
Nov 27, 2009 | Kodak EasyShare C613 Digital Camera
Sd card cannot be read & internal memory of camera cannot be read
Which Kodak camera model?
It may not support a large SD (SDHC) memory card.
Remove the card and remove the batteries.
Turn ON the camera (I know, no batteries) for one minute.
Turn OFF camera and install batteries.
Do not insert the memory card.
Does the internal memory work?
If so, insert memory card.
If it's ok to format the card, do so.
If not, then use a USB adapter and copy the memory card to your [My Pictures] folder.
Format memory card.
Oct 01, 2009 | Kodak Cameras
Won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Nov 03, 2008 | Kodak EasyShare DX7630 Digital Camera
Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
Oct 31, 2008 | Kodak EasyShare M863 Digital Camera
Cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
Feb 10, 2008 | Kodak EasyShare Z740 Digital Camera
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare P880 Digital Camera Logo
102 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
