Question about Brother HL-6050DN Laser Printer
Brother 6050. Printer prints but comes out screwed
Brother 6050. Printer prints but every now and then the paper commes out screwed. Could it be something to do with the heat element?
Change the FUSER UNIT.
Posted on Jan 11, 2011
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Tip
How to get the page count on a Brother HL-6050
To obtain a page count (also called a meter reading) from a Brother HL-6050 printer, follow the steps below. (This procedure also applies to the HL-6050D and the HL-6050DN models.)
A. When the machine is on and ready to print, press any of the following keys to bring up the menu: Set, Back, +, or -.
B. The first menu heading that appears is Information; press Set to select it.
C. Use the + or - keys to scroll through the Information menu until you see Maintenance.
D. Press Set to select it.
E. The first option that you'll see is Page Counter; press Set to view the count.
The number of pages printed so far will appear on the screen. Once you've seen or recorded this number, keep pressing the Back button until you're back at the Ready screen.
If you would rather have a printout with the page count on it, you can get that instead by simply pressing the Set button three times from the Ready screen. The first time you press it you'll bring up the menus, the second time you'll select the Information menu, and the third time you'll select Print Settings. When you choose Print Settings, three pages of information will print out, showing supply usage, jam counters, and machine settings. On the second page, about halfway down the page under the <Device Status> heading, you'll see the page count. Beneath the page count, you can also find the number of pages printed from each paper tray, as well as the page count broken down by paper size (for example, letter-size paper, legal-size paper, or envelopes).
on Sep 16, 2010 | Brother HL 6050 Laser Printer
Hi I have a brother mfc 5440cn and it fails to print but comes up with an error 50 message. How can i solve this?
Where does the Error message appear? is it on the printer or the PC.
Try a test print from the printer menu
Press Ink
Press up or down to select 'Test Print'
Press up or down to select 'Alignment
Press menu/set
press black start or colour start
The printer should start printing. If this prints ok then the problem is likely to be with the comms between the printer and workstation
Sep 02, 2011 | Brother MFC-5440CN All-In-One InkJet...
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Drum & toner were replaced and now the printer PRINTS IN CHARCOAL have replaced the drum and toner twice
I assume "Prints in charcoal" means dirty printouts. The toner is not staying on the paper?
Sounds to me like a bad "Fuser Assembly" problem.
You can source one from:
http://www.precisionroller.com/fuser-assemblies---units-for-brother-hl6050d/details_38855.html?src=gbps
Hope this helps
Mar 14, 2011 | Brother HL 6050 Laser Printer
My brother printed was printing a paper and my little brother turned of the printer and now the paper that was printing got jammed and now it is not coming out
Open the printer and take out the paper from it.
Then try to restart printer and computer both simultaneously.
And then you and only you try to print the paper not by any else.
Dec 23, 2010 | PrinterShare
Brother HL-6050DN Printer gives "replace laser scanner unit" message on led.
The problem coming because the laser unit in your printer is not working . Need to be replace laser unit to solve the problem.
May 21, 2010 | Brother HL 6050 Laser Printer
Printer wont print, paper light comes on, there is paper in tray
Reset the printer with the following method that I searched on the Brother solutions website - took an hour of searching...
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
Mar 30, 2009 | Brother HL 5140 Laser Printer
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brother HL-6050DN Laser Printer Logo
162 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
