Question about Cobra 148 GTL 120-Channels Base CB Radio
I just installed a Stryker 490HP in my big truck, the most power I seem to be able too pull is around 30-35 watts from 125 before I get some serious feedback when I key up? Rookie
  • 494 Answers
RF feedback into the radio most likely from bad SWR or poor ground counterpoise at the antenna. Change out antenna to something more capable of use with this radio. Maybe a 102 stainless steel whip or Wilson 1000 or K40 type.
Posted on Feb 13, 2010
Where do I adjust the cable on a kymco striker 125 but it has a 200cc xg Joa motor
Hi, Tony for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Kymco Stryker 125 150 Service Repair Manual Download Download Manuals... $10
Stryker II 125 DA25BB DA25BD Kymco Scooter Parts Racing Planet USA
KYMCO Stryker 125 User Manual FREE
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 11, 2016 | Kymco Motorcycles
Deristrict kymco Stryker 125
there are different methods of restricting, hear we 1. gasket between the carb and inlet. ". gasket between the exhaust and head, 3. washer in the output sprocket to drive to wheal in the centrifugal clutch Re: Jeff
Apr 12, 2012 | 2001 Kymco Stryker 125
Derestricting my kymco stryker 125
How do I derestrict a kymco stryker 125
Nov 27, 2011 | 2005 Kymco Stryker 125
Hi just got a kymco stryker, the bloke said that it would make a clunkin sound in 2nd 3rd and 5th (sounds like the chain jumping) but on the way home , he said it was best to stay out of 5th,i did so...
I doubt that the chain was jumping the sprocket. A chain that loose would wrap up around the front sprocket and lock up the engine and/or bust up the center case. It sounds like the bike has some serious transmission problems. The bike probably has bent shift forks and a few busted gear teeth and possibly broken dogs on a slider gear. The bloke ripped you off. The wheel being out of line is not a factor. Please rate my answer. Thanks.
Sep 14, 2010 | 2005 Kymco Stryker 125
Hi, what are the carburetor settings for kymco stryker 125. what the idle speed should be and how many turns out for the mixture screw. what side for each screw. many thanks
this is down to personal preference, its just playing around with it so that it doesnt stall and isnt so high that you cant accelarate.
i have mine at a lower setting in the summer and a slightly higher setting in the winter its just fiddling around with it till your happy with it.
best of luck and safe riding
Sep 08, 2010 | 2005 Kymco Stryker 125
I need to replace my starter motor for my kymco stryker. Do you know any compatible parts that is exactly the same as my kymco stryker?
i need to replace my starter motor for my kymco stryker. do you know any omcpatible parts that is exactly th same as my kymco stryker
Oct 03, 2009 | 2001 Kymco Stryker 125
Where can i get mannual
hi m8 dont know about the manual but if u go to ebay.com and tape in kymco stryker they have loads of engine parts hope this helps m8.. will g..
Jan 26, 2009 | 2001 Kymco Stryker 125
SPARK PLUG LOCATION PLEASE
Hi Dave,
I take it the Kymco 125 Stryker has the overhead cam engine either a Honda 125 or very similar?
O.k. if you look at the top of the engine just below the fuel tank you should be able to see a heavy wire going to a cap shaped a little like a Tobacco Smokers pipe it may steel shrouded or plastic? this could be obstructing the view of the Spark plug as it is in fact the plug cap that isolates the plug from water etc, if you carefully pull this upward in the direction of the fuel tank it should release showing the item you seek.
Hope this sorted it,
Paul 'W'
Onyer~EDson(:0)~[><U.K.
Jan 13, 2009 | 2002 Kymco Stryker 125
Cobra 148 GTL 120-Channels Base CB Radio Logo
236 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
