Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Low water temp Gaggia Coffee
Hi, Im only getting 170Deg F out of the machine. shouldn't it be up and 190 or 195deg F. Let it warm up , Ran 10 or 15 shots all 170 or under, Machine is less then a year old. thanks
  • 2,039 Answers
Descaling time with descaler not vinegar descaler melt calcium no calcium in boiler =warmer coffee vinegar remove some calcium in piece that might block somewhere else
THANKS FOR USING FIXYA
PIERRE
Posted on Feb 19, 2008
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Screen indicates to ventilate and won't allow any fuctions till ventilated. Have ran ventilate cycle several times, however machine still indicates to ventilate. Water flow is extremely low to nil when...
If you open the steam knob and only can get a half cup of water, then your flow meter in the machine have to be replaced.
If you need to replace the flow meter then it has spare part number: 286473300
Make sure to descale your machine often.
Jul 20, 2008 | Gaggia Titanium Espresso Machine
Gaggia Titanium. . coffee not hot even though
Remove the filter holder and brew some water into a small plastic cup and check temp, it could be the thermostat for the coffee temp is damaged.
Apr 29, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Our Gaggia Tianium is stuck on rinse cycle, water pouring out
Just let it run the cycle,don't press any buttons.
When it runs out of water refill it and let it continue.
I get this problem a lot,
Dec 26, 2009 | Gaggia Titanium Espresso Machine
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
My Gaggia stopped pumping after I ran it pumped for 10 minutes
Hi
First thing don't use vinegar because it can damage your machine. Citric Acid is what you should use. You may need to prime the machine again. Force water down the intake receptacle below the water tank.
May 03, 2009 | Saeco Vienna De Luxe Espresso Machine
Gaggia classic not producing hot coffee
Two questions; is the water coming out of the head without coffee hot and can you get steam out of the wand?. If yes to both then try running the group with the portafilter in it to warm that up before making a coffee.
Mar 26, 2009 | Gaggia Classic Espresso Machine
Gaggia Evolution Filtering Weak Coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jan 03, 2009 | Gaggia Evolution Espresso Machine
? Am I trying to use coffee ground TOO FINE
On my Gaggia Machine I use an Gaggia MDF Grinder on 8 or 9 setting for the best flow. I only use as low as 4 with my Presso Manual Machine
Nov 05, 2008 | Gaggia Classic Espresso Machine
Gaggia cffee machine will not pump water through th coffee
my gaggia coffee machine, will not pump water trough the coffee. I see the water going back in the reservoir. I used the cleaner cafiza, but no help. Please help.
Thank you
Jul 06, 2008 | Gaggia Classic Brushed Stainless Steel...
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
110 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
