Question about Lexmark T642 Laser Printer
Where to change the setting of a lexmark t642 printer to get the paper printed on both sides
  • Official Brand Answer
  • 3,344 Answers
The setting should be on the driver. Once you are ready to print a document just select print then printer options and you should see the option of two sided printing and select the long edge or short edge. If you want to know where in the printer menus is the option, then go to the printer menus then select Finishing Menu then Duplex and just select ON. that should activate the duplex option.
Posted on Feb 09, 2010
I can not print from my lexmark t642 printer. I get this message " Remove paper from Standard paper bin." I do not have any paper in that area.
If there is no paper on paper bin and you are getting error to remove paper from the standard paper bin, please check for paper jam. it possible that paper stuck right on the path on the paper bin.
For further assistance, please contact Lexmark Technical Support.
Sep 12, 2011 | Lexmark T642 Laser Printer
Hi The printer is asking for change MP feeder to folio, thanks
Hi
you need to change paper settings on your printer
or on your printers menu on pc
you have ask it to print you in folio
Pls vote me to keep me alive
Nov 23, 2010 | Lexmark T642 Laser Printer
The T642 jams constantly under the toner cartridge when printing from the manual tray.
Hi, Make sure you have all of your paper settings properly configured in the Paper Menu of the printer. Paper size, type and weight. Then make sure there is nothing blocking the path of the paper as it enters the printer. That will be easy to notice since if there was and obstruction the paper will get damaged. If there is nothing in the paper path then the printer must be giving you an error. If its a 201 then the input sensor(little plastic flag under the toner) could be damaged. If it gives you a 202 then maybe the fuser exit sensor is damaged. In that case you will have to contact Lexmark's tech support so that you can get help if your printer is still under warranty.
Dec 14, 2009 | Lexmark T642 Laser Printer
Lexmark T642 - I have plain white paper in tray 1 and yellow plain paper in the mp feeder tray. When I choose to print to the mp feeder tray the printer beeps to be loaded with paper but the paper is...
Make sure you have selected the multi purpose feeder (front of the printer) in the driver, not the Manual Feeder.
The manual feeder will prompt for paper on each page. All you have to do is to press the "Go" button.
Jun 03, 2009 | Lexmark T642 Laser Printer
Lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
Mar 11, 2009 | Lexmark T642 Laser Printer
Printer problem
Check your paper configuration. Make sure Tray 1 is configured for Plain paper and is showing the right paper size. If it is configured for anything other than Plain Paper, most of your jobs will not print. Also, if the size says something like Univseral, then the printer is not touch that tray unless your print job also specifies Univeral as the size. If is does say Universal, check the paper guide in the tray and make sure it is pointing exactly at the paper size you are using
Dec 12, 2008 | Lexmark T642 Laser Printer
Lexmark T642: Will not print text files in Linux
Sounds like there is something corrupt with the driver or the wrong driver is associated with the printer. Delete the printer from the computer, but leave attached. Download the newest driver directly from Lexmark and execute the download. The computer should then automatically re-install the printer.
please visit the link below to download the correct driver for your printer directly from Lexmark.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
use the product selector to enter your model number and operating system.
Sep 03, 2008 | Lexmark T642 Laser Printer
Lexmark 642 printer on network will not print to tray three. When anything is sent to tray 3 it goes to tray 2 even though we set it up in our application to trigger $C(27)_?&15H?
I have found that if the print job needs a certain paper size and the tray is reporting a different size loaded into it then the job will pull from the next tray with an acceptable size. Lexmark's paper stops in the trays are easily moved by the wieght of paper loaded in it. If the job requires "Letter" checnk the size tabs on the left side of the tray, they are on the outside of the tray. For "Letter" just the buttom 2 tabs should be sticking out, adjust the green back stop until just the bottom 2 tabs are sticking out and try your print job again.
Jan 22, 2008 | Lexmark T642 Laser Printer
Lexmark t630
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Nov 20, 2007 | Lexmark T642 Laser Printer
You need to download the Postscript drivers from Lexmark site.
Oct 28, 2007 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
178 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
