1. Take out the battery
2. unscrew the four torx4/torx5 screws including the one under warning
label but no need to touch the phone idenity label ;)
3. unscrew the two side screws located near top
4. take out pen and any card in device
5. carefully remove back (now you will be able to see the circuit board)
6. looking at the phone LCD down so you see the circuit board remove
screws (small Phillips/ cross-heads silver in color).
1.top left.
2. top right.
3. middle right near small cable.
Now you should be able to move the circuit board (do not force apart).
The LCD cable and keyboard cable are attached to the underside of the
board.
1. Slide the phone 50% open (but keep phone LCD face down so you are
look at the board phone the (keyboard being closest to you than main
speaker). .
2. Carefully lift left side of board (you should see the cables) using a
small screwdriver Very Carefully pry them off the board (the should pop
off with no force needed).
3. Slide phone fully open and now you are able to see all 4 torx screws
that hold the front part of the phone on just under the circuit board.
* Bottom 2 are in small cut out boxes just under to circuit board you
may need to slide the front up or down to align with the screws.
*The top 2 you should have notice when you fully opened the phone in
normal use and looked at the back of the LCD at top behind speaker.
4. The front surround and LCD and buttons will come off. Carefully remove
from bottom near the navigation buttons.
5. The phone should now be able to divide into the two sections with cables.
6. Unscrew the the LCD and the cable 2 top 2
bottom for LCD - but you have to also remove the button ribbon cable.
replace LCD and reverse process
*the LCD cable needs to be pushed into the socket on the underside of
the circuit board (this can be tricky so take your time).
*Note: the keyboard cable is similar to the LCD cable but it has a smaller
socket.
Answer 1:
From your description, the LCD is cracked. The outer glass you described is the touch screen digitizer and it sounds as though this is intact. If it was broken, even with the LCD visibly cracked, you would see that it was also broken. A similar question was asked in the forum titled, How do I replace a cracked screen?
In reviewing that post, the first answer indicates that the digitizer can be replaced independently from the LCD. Upon doing a search on Amazon for the LCD itself, I did find one listing that you could use to purchase it separately. However, the disassembly video in that post was focused on replacing the digitizer.
I found a similar video on Youtube, titled RCA 10" Screen Replacment - Disassembly - RCT6203W46 PRO, which may be more relevant to start from the back and work your way to the LCD. This video goes as far as replacing the digitizer, but you'll just need to remove the LCD and the respective connections and attach the appropriate ones to the new LCD.
Furthermore, I did a search on eBay and discovered that there are two versions of the LCD. One that is a straight lcd cable and the other that uses an l-shaped cable. It is important to purchase the correct one. This ebay listing is specifically for the straight cable, but the seller also sells the l-shaped cable as well.
How do you know which one your tablet has? You may need to disassemble it to find out, as there was no specific documentation that I came across based on the model number or manufacturing date that indicated a specific way to know. You could try contacting RCA support, but disassembling helps confirm it before you decide to order from eBay, Amazon or any other third party.
You have to disassemble the TV; fully; to replace it. Should have all tools to disassemble it, and much experience in work too.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Disassemble media player and remove broken lcd. Like all other lcd screens, there must be a serial number or model number written on it.
Search that serial number on internet. You may also ask manufacturer if they may provide a new lcd screen. If you can not find a new screen, as a last resort you may try to find faulty same product to replace it's working screen with your broken one.
Sure. It can be replaced. In order to do this, you will need to disassemble the LCD screen panel in order to gain access to the screen itself. Replacement LCD screens can be purchased here: http://www.lcdparts.net/
