Question about Kenmore Sewing Machines
Bobbin bunches up when sewing - Kenmore Sewing Machines
  • acarriero Feb 02, 2010
    I tried all things you suggested but bobbin still bunches up .
  • 10,515 Answers
Whenever the stitching is not even on the top and bottom the bobbin tension or the upper thread tension needs to be adjusted. When they are not set correctly the looser thread loops up and the stitch does not properly engage, allowing you to pull it apart.
You will need to adjust the upper tension knob; To test if the thread is being held by the tension discs properly when ready for sewing, you need to pull the thread from where it comes out of the eye of the needle-with the foot lowered. The thread on all machines should be tight enough to bend the needle when pulled. If it does not then you need to investigate why it is not tight. The most common reason is a restriction between the tension discs themselves, caused by fluff, corrosion or trapped threads.A loose top thread leads to a bunching of thread UNDERNEATH the work (or looping on minor tension failure). Once you have done this put your numbered tension dial half way, for instance if you have a dial that goes from one to four put it on two, one to nine put in between the four and five, etc. On older machines with no tension dial numbers turn the dial clockwise until the thread bends the needle when pulled through as I have mentioned earlier. Then leave the top thread tension alone, until using a different type of thread.
If you have your manual, it will explain it the best.
Here is a link to adjusting the tension correctly :-
http://www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf
You need to have Acrobat Reader to View the File.
I would verify that the upper thread path is correctly installed and that the bobbin and case is inserted correctly. I would also verify that the needle is the correct needle for the machine and that it is installed in the correct position; with the flat top section against the flat part of the holder. If the needle is bent, I would change it.
I would also verify that the dogs, that move the fabric
, are in the up position.If everything, mentioned above, looks good then you will need to have the hook/needle timing checked. The needle and hook tip must meet at the right time for the thread to be picked up. If the timing is off adjustment is required and I would have this fixed by a professional.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
    Brigadier General:
  • 3,917 Answers
Hi
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. Tighten the tension on the top thread a little bit and everything will be fine.
After putting the bobbin in the case and pulling the thread the bobbin should turn clockwise.
Also it can be that the upper thread has missed going thru the tension section of the threading process.
So return the top tension to the normal setting, re-thread the machine and make sure the bobbin is in correctly. If this does not correct the problem, then it’s time for a visit to the repair shop.
Also be sure to clean the lint out of the bobbin area.
Thanks for contacting fixya.com
Posted on Feb 02, 2010
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
Thread bunches up when replacing thread on bobbin
If the thread is bunching or tangling when winding a bobbin, check that you have properly threaded the winder. Especially make sure you are running the thread through the bobbin tension assembly.
Aug 21, 2014 | Singer 5050 Mechanical Sewing Machine
How to adjust bobbin when using embroidery machine, bobbin thread bunches up
Check your bobbin case if it looks like it has and feels like there are barbs on it they catch the thread time for a new bobbin case. I had mine less than 2 months and had to get one my machine sews and embroiders great now
Nov 25, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
My bobbin tension thread is bunching up and not sewing right, top stitch is fine? I've moved the tension control number each way and this does not help at all. I've tried different bobbins also? Help!! ...
Recheck your bobbin and make sure it's in the bobbin case correctly.There may be arrow diagram on face plate or bobbin case. You can also check owner's manual to make sure bobbin is inserted the right way. If it isn't, the bobbin thread can "whiplash" causing the bunching you've describe. If you have smooth stitches on top, your top threading is all right. I hope this helps. If it does, please let Fixya know by rating my solution.
Nov 30, 2010 | Singer Stitch Sew Quick Sewing Machine
Bobbin thread is bunching up and wobbling
you don't have it threaded right and you have to make sure the thread is seated between the top tension disc
Jun 28, 2010 | Husqvarna Rose
I have a WHITE 3300 EMBROIDERY MACHINE and the thread bunches up at the bobbin site. I have tried a new needle, adjusted upper thread tension , changed bobbin threads and nothing helps, it keeps bunching...
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Mar 18, 2010 | White Sewing W3300 Computerized Sewing...
Sewing Machines Logo
23 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
