Question about Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV
Tv has double pictue and yellow and green color
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 02, 2010
  • 10,594 Answers
Double picture is due to convergence out chips failure in tv, replace convergence out chips (quantity 02) to fix the problem.
Let me know if you want to replace these chips by yourself, please note that it requires soldering work in circuit board of tv with proper tools.
Thanks.
When I hook up DVD player to 32inch LG television there is no color on the TV it plays in black and white. Why?
first check color level setting on the tv when on av source input. double check input you are using, yellow video input (not green)
then try another device in that same input, then try the DVD player on another tv. The problem will be either DVD player or incompatibility or bad main board in TV, but usually a DVD or compatibility problem(cheap DVD player)
Mar 22, 2015 | LG 32LD450 32 In. LCD HDTV
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
The picture is green ?
The screen colors are all derived from three distinct colors. Red, Blue and Green. The colors can change due to a few problems. The purity or converge could have been disturbed due to magnetic interference, one or two of the color amplifiers have stopped working or the picture tube has failed. Color problems can be as easy as circling a high magnetic field coil in front of the set, known as 'degaussing' or extremely technical, frustrating and then hence expensive. Not much help, I know, but good luck.
Jul 13, 2014 | ESA ET427E 27" TV
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Showing irregular colors are red green and yellow and doubles
Tv have a problems known as a picture convergence problems,it is dead.Tv have colors R,G,B lines are mis alignments in pictures,have colors shadows pictures or 3D picture look alike?Yes,than the tv convergence board it dead,tv must require replacement on the tv convergence board like 2 STK conconvergence ICS and some or all of it resistors too,to fixed the tv convergence board to solved tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Jul 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
There is blue yellow color blur on the screen with cable or dvd
This problem is of "CONVERGENCE". You have to replace the convergence IC's which is better to buy a new one TV, Just contact any expert and replace the convergence IC's and your TV work fine again you need not to buy a new TV.
Thanks for using fixya.
Jul 24, 2009 | Toshiba 42H81 42" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Wire color to radio
light green and dark green -- right front speaker
tan and gray -- left front speaker
light blue and dark blue -- righr rear speaker
yellow and brown -- left rear speaker
orange -- constant power
yellow -- switched power
black w/ white stripe ground
always use a dc electrical test light to be certain your power connections are correct.
May 20, 2009 | Car Audio & Video
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
