Question about Mitsubishi HC1600 Projector
How do i reset the lamp timmer after replacing the bulb?
  • 144 Answers
Menu, setup,lamp settings,lamp reset.
Posted on Feb 13, 2010
HOW DO YOU RESET THE LAMP USE TIME ON THE JVC HD 56 G787 REAR PROJECTION
u need the real remote rm-18g hit menu till u get to lamp reset hit enter a screen will come up that says press ok to reset lamp timmer hit ok button than another screen will come up that says the lamp timmer was reset successfully
Sep 08, 2013 | JVC HD-52Z575 52" Rear Projection...
I HAVE REPLACED MY BULB OM MY KDF-50W655 AND MY TV IS WORKING AGAIN, BUT I HAVE TRYED TO RESET THE TIMMER TO THE BULB THRU NMY CONTROL....BUT CAN'T SEEM TO MAKE IT WORK...
I have installed the new lamp and the the led power light comes on green and than turns flashing red. What is the next step in this repair?
Mar 21, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Our projector indicates that the light bulb needs to be replaced after replacing the light bulb once it still indicates that it needs to be replaced.
This is the excerpt from the manual on how to reset the lamp life timer.
Turn on the projector and use "Lamp Reset" after the lamp module is replaced.
Lamp Reset: (i) Press "Menu" ?§ (ii) Select "Options" ?§ (iii) Select "Lamp settings" ?§ (iv) Select "Lamp Reset ?§ (v) Select "Yes".
Jan 12, 2011 | Optoma HD65 DLP Projector
I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Resetting lamp meter to 0
TO RESET THE LAMP TIMMER PRESS THE VOLUME DOWN BUTTON ON THE FACE OF THE TV AND THE OK BUTTON ON THE REMOTE AT THE SAME TIME FOR 6 SEC.
Apr 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Replacing bulb
hold the volume up/down in ,switch unit on while holding these in for 30 secs, if that fails, flash unit with new software.
Dec 01, 2007 | InFocus In Focus SP-LAMP-021 Replacement...
Mitsubishi HC1600 Projector Logo
507 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
