Question about Nikon Speedlight SB-800 TTL Flash
Flash zoom function not working
The flash is working fine, but the flash zoom function is not working properly. It does not move as you select different zoom settings. Do you know what the fault could be and if it is a worthwhile repair?
Have you checked that the diffuser is pushed fully home in its slot until you hear a click - this diffuser is for close-up work only and dissables the zoom flash
Posted on Feb 27, 2010
    Champion:
  • 254 Answers
Hi Jon,
Is zoom set in Auto Mode?
In Auto Zoom, you can't set it manually.
Does zoom lens zooms the flash?
a.l9609@gmail.com
Posted on Feb 05, 2010
Is not working properly
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Apr 18, 2014 | Canon SPEEDLITE 580EX TTL Flash
Zoom--mm blinking and can't change mode
Your zoom motor is probably stuck. Remove the two screws on the front side of the tiltable head. Pry off the two tilt caps using a small flat head screwdriver (they are glued on). Remove the 4 screws found under each cap. Now you can separate the two sides of the head and take out the two lenses (remember exactly how the lenses were positioned). Try pushing the flash in or out (it should move with a little force). See if the flash now responds before reassembling.
Mar 21, 2010 | Canon Speedlite 430EX TTL Flash
I am using a Speedlight sb-800 on a Nikon D200. I cannot get the Zoom M function to change to Zoom. Any ideas?
Take flash out from hotshoe.
Can you set flash zoom manually?
When using Nikon Nikkor zoom & zooming, does flash zoom or hear motor sounds from head?
atdlee@netzero.com
Jan 16, 2010 | Nikon Speedlight SB-800 TTL Flash
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
Flash function not working
Try resetting the camera. If that doesn't work then it would have to be sent in. In the picture taking mode pess menu and go to the setup tab. Go down to reset and press the right arrow. HIghlight ok and then press select. If that doesn't work then send it in to be fixed.
Aug 01, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Frozen on one setting
Try this site and follow the photos.
It worked for me.
327093-how-repair-canon-speedlite-580-ex-dupa-ce-vibreaza-capul.html
May 26, 2008 | Canon SPEEDLITE 580EX TTL Flash
Red Eye
If the red-eye reduction is turned on, and you can verify that the pre-flash is functioning, you may need to think about shooting technique. With ultra-compact cameras, the flash is necessarily placed close to the lens. This is the worst design possible to avoid red-eye. To reduce red-eye as much as possible, ensure the red-eye reduction system is turned on (and functioning properly), and get close to the subject. I mean "physically" close, not just close by zooming. Use as little zoom as possible. If the subject is small, move closer, without relying on the zoom lens to make the subject appear closer.
Mar 08, 2008 | Canon PowerShot SD1000 Digital Camera
Canon 430EX Flash
I have a 430ex and S5, I don't think the zoom head will move without being mounted on a camera.
If the flash test fires ok, then it should be fine.
Oct 16, 2007 | Canon Speedlite 430EX TTL Flash
Power zoom function
If you have the difuser on the zoom does not work as it assumes you are at close range. Remove the defuser and try again, good luck , Bob.
Jan 05, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
503 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
