Question about Dishwashers
My dishwasher is not cleaning the dishes.when the dishwasher is done there is still stuff on my dishes. if you cancel the cycle the water in the dishwasher is cold
    Problem Solver:
  • 10 Answers
If the machine used to work fine then I'd suggest running the hot water in your sink before starting a cycle to ensure the water entering your dishwaher is hot. If you then are getting hot water and still dirty dishes try reposting for a a solution. When re-posting, include your make and model for a better answer.
Posted on Feb 04, 2010
Leaving a white residue on dishes after its full cycle. Have tried different soaps,rinsing agents, and ran it through a cycle with a cup vinegar in it.Is there something I can do to repair this problem ?...
As you have already done the vinegar cycle and all now it must an technical reason.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 17, 2011 | Frigidaire Dishwashers
Dusty white stuff on dishes, and build up at the top of the door.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Jan 27, 2011 | KitchenAid 24 in. KUDP02FR Built-in...
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Amana dishwasher not cleaning
make sure water valve is good and you are getting hot water to your d/w run sink in kitchen to get water hot before running d/w
Oct 09, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Lots of stuff left on dishes and glasses real filmy
run unit through a clean cycle. turn on hot water at sink til it gets hot then shut off . then tuen ion dishwasher when it starts washing open door and add 2 cups of white distilled vinegar and let it go through a cycle ( no dishes) when done. turn on hot water at sink before you use dish. also fill both soap cups and use rinse aid or jet dry. you should see better improvements. hope this helps..
Sep 17, 2009 | Kenmore Dishwashers
Dwu7400aax - dishes do not come clean eough
make sure you water is hot enough, manufactures reccommened 120 degrees to the dishwasher, i advise all customers to run hot water at sink til you get hot water then turn dishwasher on, also fill both compartments of sopa, also use rinse aid or jet dry, do not use gel packets. use cascade powder or liquid only.also run the unit through a clean cycle this should be done once or twice a year. letdishwasher fill with hot water. when starts to wash, open door and add 2 cups of white distiilled vinegar and close door and let it go throughas cycle. no dishes. also i reccommened dish majic cleaner sold at walmart or grocery stores. if this dont help then youw wash syatem could be bad or going bad.hope this helps you. try all these things first befor you re[lace uniy or pay to have it looked at.
Sep 17, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Dishwasher has water left in it when it is done cleaning.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine.
Apr 03, 2009 | Whirlpool 24 in. DU850SW - Multiple Color...
Dishes still dirty
Apr 03, 2009 | Dishwashers
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
