Question about Belling XOU592 / XOU593 Electric Double Oven
Dead oven despite element replacement?
Hi, I've just replaced the element in my oven (belling 592ss), as the fan was working but it wasn't heating up, and now it appears completely dead. The top oven and grill works fine, but the oven doesn't come on at all. any ideas?
Cheers,
Pete
  • Belling Master
  • 3,463 Answers
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
Posted on Feb 02, 2010
How do use reset timer
Posted on Dec 21, 2012
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Tip
Belling Elements
on Aug 25, 2010 | Belling XOU592 / XOU593 Electric Double...
Tip
on Aug 25, 2010 | Belling XOU252 Electric Single Oven
Tip
on Aug 25, 2010 | Belling XOU174 Electric Single Oven
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
Belling XOU592 / XOU593 Electric Double Oven Logo
763 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
