Question about Radio Communications
HI friends i allready have the VHF MIDLAND CT-210 is it possible to unlock it,,,,now it can only get 136-174000 i would like it to get every channel it can thanks a lot
4 Suggested Answers
Neto
  • 123 Answers
SOURCE: How do you unlock the channel?
Press and hold the Lock key for 5 or 10 seconds until a beep sound is heard.
Good luck
Posted on Oct 24, 2007
dobhan
  • 105 Answers
SOURCE: help with antenna
I think the whip antenna is for mobile,I suggest to get an aerial antenna even an omni type and of course the impedance is 50 ohms and try this antenna a cushcruft the model s ringo ranger 2, it is tunable antenna,I already test it from 2001 up to present,its working fine...
Posted on Mar 13, 2008
SOURCE: VHF Unlock
Radio off, use moni & menu toghether, start radio keeping the 2 pushed for some time until SELF apears on display. Then insert magic code 5858. There are now 2 values on screen like 136 174 first is lower limit, second is higher limit, after moding ude Enter and restart radio. Remember that at extreme ends pll may not lock on tx or rx or both, this is phisycal limitation of the radio board.
Posted on Jul 17, 2009
Free manual for a midland pacific vhf hand held radio
To download the manual, click 'Midland Pacific' (sixth from bottom) on the list of Midland manuals on this page:-
www.midlandradio.eu/manual/manuals_en_190875.aspx
The English language section starts on page 16.
Jul 17, 2014 | Midland Radio Communications
Midland 70-340A 2 ways VHF RAdio
It sounds like interference.. I wouldn't worry about it too much.
Dec 22, 2007 | Radio Communications
Need a midland 74-210 weather radio manual
I posted (or attempted to) a manual 5-22-11....if it doesn't show up contact me.......
Apr 21, 2011 | Midland 74-210 Radio
Midland 1001Z Channels
Hi yes it is possible as is anything if your willing to pay for the conversion , it would require new chrystals and resetting of the If system but is possible . However porobably not economical Midland did do The 100 model in an Fm modulation format and you will probably find still available on Ebay or Amazon if not that paticular one a good version at any rate ..I beleive they did actually do an Am Fm model also ...Regards Vortash
May 04, 2009 | Midland 1001Z 40-Channels Base CB Radio
Radios comparable?
First, select the radio frequency band which would best suit your needs. (ie: VHF, UHF or 900 MHz) If you are talking in and around concrete and brick you would want to select the UHF or 900 MHz.
Second, with your frequency band chosen, narrow down the field of radios which have the features you like. (ie. number of channels, amount of wattage, text messaging, or plain jane, etc.)
Third, compare apples-to-apples. If you decide a 1 channel, 4 watt UHF radio would suit your needs, compare all brands with this criteria.
Fourth, look at the MIL SPECs of the radios you've selected. This will tell you much about their durability. (Some of the low cost radios will show up as lacking in this area.) The MIL SPECs are available for every radio on their product literature, and most likely on the internet.
Fifth, look at the size and weight of the unit. A radio might look great on paper, until you find out it is the size of a brick.
Sixth, look at repairability. Once your radio is out of warranty, is it repairable, and at what cost.
Seventh, look at battery, antenna and belt clip replacement costs. In two years you will need to be replacing those rechargeable batteries.
Hopefully, this will get you started. If you have questions, repost here, or talk to a radio dealer or two. IMHO most schools use UHF 4 watt models, or the newer 900 MHz (license-free) digital radios with success.
Sep 04, 2008 | Radio Communications
Midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Midland 1001Z 40-Channels Base CB Radio
Good luck
Oct 23, 2007 | Midland M222P (22 Channels) 2-Way Radio
Lost manual
instructions for programming the Midland 74-210 are here:
http://www.srh.noaa.gov/mob/nwrhelp.shtml#Midland74210
Sep 03, 2007 | Midland 74-210 Radio
Tuner and AV problem
TRY TUNER ASSEMBLY SOLDER JOINTS COULD BE DRY OR CRACKS GOOD LUCK
Nov 06, 2006 | Panasonic CT-20G13 20" TV
Radio Communications Logo
422 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
