Question about Acer Aspire One A150-1006 Notebook
My son (9 yrs)has an Acer Aspire One and for some reason it will no longer turn on, even after a full charge. My daughter (11 yrs) had a similar problem and it cost me $150 to fix. According to technician the power needed to be flushed? Please help
  • 733 Answers
Try removing the battery and connect the power cable and try turning it on. If that does not work hold the power button down for about 10 seconds(with battery out) to remove left over power(flush). put battery back on and try to turn on. if it still does not work, there may be a harware issue and you may need to take it in for service. And by the way, if it turns on with the power cable connected and no battery, then the battery may be faulty.
Posted on Feb 08, 2010
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
ASPIRE NETBOOK BIOS CHARGE PROTECTION
Its not your bios but your battery. Replace battery. and like a cell phone battery give it a full charge and then use it fully at least 3 times.
Oct 02, 2012 | Acer Aspire One AO532h2588 Netbook
My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
Sep 10, 2011 | Acer Aspire 5732Z-4855 Notebook
We have an acer a0751h and the battery does not hold a charge. I have heard this could be a BIOS problem. The computer is two years old or more so it may simply be a dead battery. Is it worth...
Hi
Most battery unfortunatly only have about 2/3 yrs life if one is lucky
i have 2 acer laptops one battery lasted about 2 and half yrs the other has gone on for about 6 yrs
but i finally had to repalce both
i got them from ebay a replacement from china took 3 weeks to arrive
but i knew that when i ordered and it was only around £22 where as they are normally twice that
the latest one i just bought for my acer aspire 5630 is a 9cell battery which last far longer than the
normall 6 cell battery and that was only around the £22 mark as well
Feb 19, 2011 | Acer Aspire One PC Notebook
My Acer Aspire One was working perfectly untill today, now it wont connect to the internet either by erthenet cable or wireless, each time i click on the browser icon it thinks about if for a few seconds...
Here are some suggestions that may help you resolve your Acer Aspire One problem.
Try to eliminate possible causes by
1. Shut down / power off all the PCs - the Aspire One and those belonging to your son and daughter.
2. Shut down / power off all game or multi-media consoles that can connect to internet via router.
3. Power off any another network connected devices (hard drives, printers, scanners, picture frames)
4. Power off your wireless router and cable/dsl modem for about five minutes.
5. Power on your cable/dsl modem.
6. After a couple of minutes, power on your wireless router.
7. Power on your Aspire One and a few minutes after desktop is loaded, shut off its wireless.
8. On the desktop's Taskbar, make sure the Wireless Network Connection icon has a red x beside it.
9. Look for the double-screen icon representing Local Area Connection in the desktop's Taskbar.
10. If not there, click start, control panel, network connections and right-click Local Area Connection.
11. Click enable on the pop-up to enable the Local Area Connection and its icon appears with red x.
12. Connect ethernet cable from one of the router's RJ-45 LAN ports to Aspire One's ethernet port.
13. The red x should disappear from the double screen icon in the Taskbar.
14. Hovering your mouse cursor over the icon should get a pop-up with the connection's status.
15. If OK, click on your IE browser icon on the desktop.
16. If nothing happens, click start button at bottom left and click on IE in start menu or program list.
17. If nothing happens, press Ctrl and Alt and Del key together to bring up Windows Task Manager
18. In WTM, click Applications tab to see if IE Task is running.
19. If not, click Processes tab to see if iexplore.exe process is running.
20. If not, check if you can start anything else such as Notepad.
21. If nothing starts, you should consider doing a recovery using Acer eRecovery Management.
22. If IE does start, click on its Tools tab then click on Diagnose Connection Problems...
23. Follow on-screen instructions to diagnose your connection problem.
24. If successful, close down IE, remove ethernet cable and restart the Acer Aspire One.
25. Disconnect the ethernet cable and turn on the Acer One's wireless with its wireless switch.
26. Big green letters "Wireless LAN Enabled" should appear momentarily at bottom of desktop
27. Followed by a pop-up balloon over the Taskbar's wireless icon announcing connection made.
28. Open IE browser again, click on its Tools tab then click on Diagnose Connection Problems.
29. Follow on-screen instructions to diagnose your connection problem.
30. If OK, the problem may be an interaction with one of the other networked devices/systems.
31. Redo this procedure but power on one of the other devices/systems before the Aspire One.
32. Redo one at a time for each of the other device/systems.
33. If the Aspire One is found to be OK with all of the devices/systems connected one at a time
34. Then the problem may be when ALL of the devices/systems are on and connected.
For example, depending how it is setup, the router's DHCP may have run out of IP addresses.
Another example is IP address conflict due to systems not flushing their IP cache on restarting.
These two examples assume the problem exists regardless either on wired or wireless connection.
If just one of the devices/systems is causing the problem, it may have been infected with a virus.
Jan 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 3000 ram installation - how to?
take 2 screws out on bottom - section / engraving like this (small)
______
take out ram chip and replace
screw screws back in.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!WARNING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WILL VOID MFG. WARRANTY. IF YOU DON'T WANT TO VOID WARRANTY, GET RAM INSTALLED AT PLACE LIKE BEST BUY
NOTE: I TAKE NO RESPONSIBILITY FOR DAMAGE. I AM 9 YRS OLD, BUT HAVE BUILT 9 COMPUTERS.
Mar 18, 2010 | Acer Aspire 3000 Notebook
When the battery on my acer aspire 5050 is fully charged, it only lasts for about 40 minutes
then it is time to get a new battery and see if you can upgrade it to a 9 cell for longer up time.
Aug 28, 2009 | Acer Aspire 5050-3242 Notebook
Acer Aspire won't power on with fully charged 9 cell battery!
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Mar 08, 2009 | Acer Aspire One AOA110-1626 Notebook
Acer Aspire One A150-1006 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
