Question about Toshiba Satellite A100-S8111TD Notebook
No drivers are installed for this device.
I cant open my ide hdd enclosure device
    Genius:
  • 1,189 Answers
Hi, this may help you out; from the Start Menu, open ,and Type; in ("search box") Toshiba. In the Programs listing, select "Toshiba Application Installer," click to open the Installer, the "Wizard" appear, click on the "Next" button, and in the (left) item pane; choose the items ("Highlight") you want to install, click on the "Install" button after each selection. "Restarting the computer is always highly suggested."
Posted on Feb 02, 2010
External 3.5 inch IDE hdd encloser connected via USB is showing "device is not ready" when try to initialise it in the disk manager
Check the jumper settings of the IDE hard drive you have in the enclosure for compatibility in your setup. (Choices are Master, Slave and Cable Select).
Feb 06, 2014 | Computers & Internet
Transfer files from crashed computer to good computer
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 AU $8.40 Buy it Now + postage AU $0.96 you could get this on Ebay if you dont have an account you will need to create one https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account On Ebay summary page you will see on left a paypal link When you get to the paypal login page at the bottom you will see new to paypal sign up tab Paypal to create an account Paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search Always ask questions ? Before you make a purchase and keep the email /s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. or you might be able to find one closer for local pick up
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable
http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4 USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit AU $7.46 free postage worldwide You would have to remove the hard drive and use a usb sata ide kit you will then have to connect it to your computer using a usb port Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually click start click on computer to open you should see this drive If you dont. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X you will need to update/reinstall drivers right click to reinstall drivers. If you can see your usb drive but its not working ports (com&lpt) right click update driver Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive or you might get one of these depending on the connections of your hard dive http://www.ebay.com.au/itm/NEW-2-5-SATA-USB-2-0-external-HDD-enclosure-case-AU-/221010079433?pt=LH_DefaultDomain_15&hash=item33753a2ec9 NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
Hope this helps.
Jan 22, 2013 | IBM ThinkCenter S51 (8171Y1A) PC Desktop
Getting data off HDD from Caddy ?
I have had similiar issues using caddies there seems to be many connecting parts that can fail or become old and dirty failing to make contact with the hard drive you could remove the hard drive and check these contacts make sure they are clean and making contact
or
You could just remove the hard drive from the caddy and connect it directly inside your computer as a normal hard drive
or
http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE
If you dont.
or get one of these
Hope this helps.
Nov 23, 2012 | Computers & Internet
Can't read HD-- I/O error
"Joecolvette" has probably got it right, I've seen this before. The HDD enclosure circuit board has a fault. Can be resolved by replacing the enclosure. Plenty on ebay, just ensure you buy one with the correct HDD interface (Sata or IDE).
Alternatively, if you have a tower with a spare port, you could take the HDD out of the caddy, install it in the tower as a "Slave" (check jumper settings) ensuring the system drive is set to "Master". Then you can check whether the HDD itself is at fault.
Apr 28, 2012 | Maxtor Computers & Internet
I am a complete novice, can you help me please? I have purchased a 3.5 SATA/IDE back up enclosure to transfer files from old to new desktop. I have removed frame holding old harddrive into tower but cannot...
You want to remove the hard disk from old computer, connect it to the enclosure, and connect it externally to the new computer, right?
Now you have a problem connecting hard disk to the enclosure.
Usually there are no SATA/IDE enclosures. They are either IDE or SATA.
If the data connector in the hard disk (HDD) is rectangular with around 40 pins inside, it is an IDE HDD. Else if it has L shaped horizontal connector, it is a SATA HDD.
I suggest you to take the hard disk to the store and ask for a matching enclosure. If you bought the wrong one, they might replace it with the correct one.
If you feel you want to do it yourself, let us know. However an IDE HDD cannot be connected to a SATA enclosure and vise versa.
I sincerely hope you will get to copy the required files to your new computer. However before copying, it is better to install a reliable virus guard.
Sep 14, 2011 | Computers & Internet
I have the imicro 3.5"
the hdd enclose may be bad/faulty
try connecting the hard drive inside your computer doing away with the hdd enclosure
the light only means its getting power not a connection to hdd
hope this helps
Dec 15, 2010 | Western Digital imicro IM35ST320SI 3.5 IDE...
I have a new (2010.09.16) Gateway DX4840 desktop w/ a 1 TerraByte HDD, 8 G RAM, Intel i3 dual core processor @3.07 GHz. The HDD and CD/DVD Burner are SATA interfaced with 4 empty SATA ports on the...
Should not be a problem but here is a thought. Have you change the jumper on the IDE drive to secondary? Failing that, can you contact the IDE drive company for help?
Jim
Oct 03, 2010 | Gateway Computers & Internet
Is my hard drive broken? Cant get it recognised on other PCs
I'm having a similar problem with the same Akasa integral enclosure, so far I have tried 3 different hard disks and not one of them will work properly and on two different computers.. , all of the hard disks I've tried are Samsung .. but I'm sure that makes no difference. I plan to send back the enclosure to where I bought it from and get a different one from a different manufacturer.
Dec 10, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
HDD enclosure does not work
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Toshiba Satellite A100-S8111TD Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
