Question about Philips 32PF7320A 32 in. LCD Television
There is no sound coming out when i tried conneccting my playstation 3 to the tv set.
  • bernamarie5 Feb 02, 2010
    I just used the hdmi cable to connect it. do i need to use the cable with 3 colors?
    Hi!
    i just used the hdmi cable to connect the console to the tv. do i need to use the AV cable aside from the hdmi cable?
    thanks!
  • Philips Master
  • 19,396 Answers
Hi.
Check the connection cable.
If you are using AV cables, ensure that apart connecting the Yellow video input cable, you are also connecting the red/white cables.
Please let me know what kind of connection you are using , so that I can help further.
Thanks.
Posted on Feb 02, 2010
  • Ginko
    Ginko Feb 02, 2010
    The HDMI cable is much better than the three color cable.
    Just ensure that the TV is not getting Sound in from a different device (receiver) through an audio cable, like optical cable or AV.
    • Try turning on TV and console.
    • Disconnect power cord.
    • Disconnect console HDMI and plug to a different port on TV if available, if not use same port.
    • Just for testing , disconnect other inputs from TV.
    • Plug back power, and turn on console first, and then TV.
    If that does not work, then it may be a faulty cable, or a port problem. Ensure that there is no other audio input connected on tv.
  • Ginko
    Ginko Feb 02, 2010
    No, use only one cable, either HDMI or AV.
    Do all suggested previously, but also go to playstation audio settings menu, and check what audio is selected:
    You find settings on Settings > Sound Settings > Audio Output Settings
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 - picture doesnt come up on tv
hold center button for a couple minutes with all cables connected to your tv this will allign your system with your tv
Jul 16, 2010 | Sony Playstation 3 (PS3) Console
I have hmdi cables from ps3 to home theatre and from here to sony bravia tv but i have no sound!!!!
try going to system settings for sound and if that does not work do you have a seperate sound system(sound not coming from tv but system speakers.
Jan 01, 2010 | Sony Video Game Consoles & Games
No picture coming up on tv from ps3 ps3 turns on but no picture comes up on tv.. tried it on 2 tvs but same happens
ARe you getting sound?I suspect it might have flipped to hd or back to standard def, depending which setting you originally had it on Try holding down the power button when you turn it on, untiil you hear 2 beeps, this should reset the visual settings on the ps3
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
Weird
I believe only voices from other players come through on the headset. Other game sounds (cutscenes, gun shots, explosions, etc.) come through the TV. Try checking the Chat or Accessory settings on your PS3 to see if there's an option to change where the sound comes from. It'll be in the PS3 dashboard (press the PS3 button on your controller). I hope this helps and don't forget to rate. Good luck and thank you!
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 console not displaying on tv screen
Make sure all the video cable connections are plugged firmly into the back of the PS3
The sound you are hearing indicates that you are on the right track. To get the video to work you will need to select the correct channel on your TV set. Connect the video cables (yellow) to the video INPUT of the AV port of your TV and then change to the AV channel on your TV set to view the picture.
Please let me know if this did not fix your problem
Cheers
John
Dec 01, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Try going on the playstation site and downloading the update to USB or some flash memory disc and then connecct it the ps3 and install!!!!!!!!
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
Help
check the audio output settings it might be set on digital out
Oct 20, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not working
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
if that does not work then call Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Apr 17, 2008 | Sony Playstation 3 (PS3) Console
Philips 32PF7320A 32 in. LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
