Question about Dryers
Dryer keeps popping circuit breaker
Electric dryer keeps popping circuit breaker
    President:
  • 2,468 Answers
Either the dryer drum motor is getting tight from dry end bearings or the heating element is shorted to the dryer case or check the input terminals where power enters the unit,sometimes these ends burn off from current draw over time
Posted on Feb 03, 2010
3 Suggested Answers
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
  • 235 Answers
SOURCE: RE: Roper Electric Dryer, front load
You have a ground fault or short . Disconnect dryer and remove small panel that holds the cord. Check if any wires are frayed, loose or touching any other metal objects.
Posted on Jun 30, 2009
Dryer stopped working. Not spinning or anything
You will be needing someone with an electric meter, (an ohm meter or a multi-meter) to begin testing to find out if it is the dryer or the power source.
The one thing you could do is check the fuse panel or the circuit breaker box to see if a circuit breaker popped or a fuse blew.
The circuit breaker can be reset by flipping the handle a few times, a fuse would need replacement.
Other than that, an electric meter will tell if the plug socket is live or dead, and then the machine needs be taken apart to see which part has failed. Usually a fuse or a thermo-switch has popped inside the machine.
God bless your efforts.
Sep 08, 2015 | Avanti D110 Electric Portable Dryer
Keeps blowing circuit breaker
It could be the circuit breaker, those do sometimes go bad, but it could certainly be something plugged into that circuit pulling more current than it should. Try disconnecting everything on that circuit. Does the breaker still pop? No? Plug one thing in. Pop? If not, keep going until you find the one that's a problem, and check the total amount of current all the devices you have plugged in use.
Most standard plug circuits are only rated at 15 amps. For example, a toaster may pull 12, a hair dryer 10. You can't run both at the same time on one circuit.
Jul 10, 2015 | Electrical Supplies
We just started noticing that, when running the dryer, there's a smell coming from the breaker box. It smells like something electrical burning. The circuit breaker for the dryer was a little warm,...
A burning smell from an electrical panel is never a good sign. You did what a lot of people will do, and have the same results - the problem won't go away.
The circuit breaker relies on the mechanical squeeze pressure of its metal clips to maintain solid electrical contact with the panel's bus bars. The problem is likely due to a poor connection between the circuit breaker and the panel board bus bars. Over the years, the load presented by the dryer has heated those points, weakening the metal clips, changing the metal conductivity in some cases due to pitting and arcing. Changing the entire panel is probably not required - especially if there are other unused spaces for a circuit breaker to be installed.
If this is the case, I would remove the new QO230 circuit breaker and install it in a previously unused space in the panel, instead. The bus bar here should be undamaged (since it was never used before), as would be the new circuit breaker contact clips. The damage has been done to the bus bars at the original location, and that space should never be used again. The same holds true for the old QO230 circuit breaker. Install SQD blank plates in the panel cover to keep fingers from getting inside.
Next, a current reading should be taken with an ammeter or amprobe. A 30 amp breaker should have no more than 24 amps on each wire connected to it. If yours is more than that, something is wrong. If it is not more than 24 amps, measuring the voltage at the breaker and the dryer plug should be done as well. The voltage at the plug should not be more than about 3% lower at the plug.
If there is no more room in the panel, a secondary panel can be installed adjacent to and fed from the original panel, space permitting. Move the dryer circuit to the new panel and any two adjacent poles of circuits (for a 240 volt feed). The dryer circuit breaker space will be abandoned and the two additional poles will be fitted with a new QO circuit breaker to supply the new panel. Your electrician should do this work for you. This is "permit required" work and must be inspected for your safety.
I hope this helps and good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Square D Qo 200 Amp 40 Circuit Indoor...
Whirlpool electric dryer not running.
Check the blown fuses and home's circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Dryers
My neptune electric dryer keep blowing the breaker after ten min
If the dryer is running then blows the breaker , then it is not in the electric circuit, There is a fault in the dryer itself. If it blows the circuit at the same place in the cycle each time then there could be some fault in the heating coil or in the timer circuitry.
Dec 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer was working fine...then
You have a short circuit in the dryer. Check the incoming wires at the cord terminal on the rear of the dryer. If these wires are OK it could be a shorted heating element.
Sep 08, 2009 | Whirlpool LER5636P Electric Dryer
Jun 29, 2009 | Dryers
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Why no heat
Absolutely. A bad timer will not initiate the element function once the load has started. there is a point on the timer board where, the timer sends a heat signal to the element and it also controls the shutdown signals as well. the high limit thermostat controls the actual temp once the timer initiates the heat signal. if the timer is bad or malfunctioning, the element will malfunctioning as well.
Replacing the timer will fix this issue.
May 18, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool electric dryer keeps tripping main circuit breaker
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
227 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
