Question about Junkers SubWave TT-S (Ju52) Wrist Watch
The crown...by jia Liew
The crown of my junkers watch came off do you have a way to fix it??
Jia heng lighter watch parts and configuration of components?
Jia Heng Butane Lighter Watch Battery Replacement
The battery replacement for the Jia Heng Butane Lighter Watch is fairly easy. The clock face actually gets removed from the lighter body. The only tools you will need are jewelers Phillips and slotted screwdrivers; Phillips and slotted.
Remove band by compressing spring pin with slotted screwdriver by pushing in the pin. These are standard watch band pins.Remove back 4 screws to remove backThe clock face is help on by 2 screws removed from the open back, there are at the 11 and 4 o'clock orientation when looking at the back.The front will drop off.Remove the plastic alignment spacer.Replace the 377 button battery.Put it back together by reversing the process.
Attached pictures
Front
Back
Clock face screws
Plastic alignment spacer
Battery placement
Oct 02, 2016 | Watches
Loose crown
Try pushing it back in place. I had a watch like that (a Bucherer).
Sep 25, 2013 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I dont have an instruction manual for my junkers 6296-2
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please
Mar 09, 2010 | Junkers Watches
My Casio Edifice watch changes the day at 12:00 and not at 00:00 as it should. Can it be fixed?
If your watch is changing date before midnight (12 hours earlier as it should) - Pull out crown and turn watch hands clockwise for exactly 12 hours and push crown back. If it changes the date after midnight (12 hours later as it should) - Pull out crown and turn watch hands anti-clockwise for exactly 12 hours and push crown back. Don't do it from 00:00 till 04:00.
Jan 08, 2010 | Watches
Screw down crown wont screw down
Either the crown or the case tube threads are stripped. Which ever part is stripped needs to be replaced. Keep in mind that both could be the problem. Be sure you don't get your watch wet until this is fixed. Your watch is NOT sealed for water resistance if the crown does not screw down.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Tag Heuer WAH1112.BT0714 Formula 1 watch
My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Nov 01, 2009 | Gucci G Watch ladies' YA100510
Crown
Your need the following tools to take out the crown...fix the hands and fix the hands.
1. Pointed Small Forcep
2. 7 or 8 no. small screw driver
You can these tools from a hardware store.
As this work is of high perecesion you need to be very careful and need high concentration.
As you have already opened the back cover of the watch you may find an arrow(--->) mark, when you press it and pull out the crown it may come out.
Now you can fix the hand by holding it by forcep and then setting it on the pinion(centre) of the dial or the position you want to fix.
In case of any difficulty you may take the watch to service centre.
Jul 23, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
To adjust time on a watch
If your watch has a crown that pulls out to set it pull crown out half a click. Then turn crown to set watch to proper dte.
Mar 01, 2008 | Watches
Seiko watch stuck crown
The crown maybe a screwdown type. Try unscrewing (like jar lid)them pulling out the crown.
May 02, 2007 | Seiko SNA553 Alarm Chronograph
Junkers SubWave TT-S (Ju52) Wrist Watch Logo
41 people viewed this question
Top Junkers Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Junkers Watch Expert? Answer questions, earn points and help others
