Question about Hotpoint Freezers
Water collecting in fridge well
I have the iced diamond r134a, but have found that the water well at the back in the main refridgerator compartment is collecting water and not syphoning this out again so that it spills into the fridge itself...can anyone help with this issue?
    Problem Solver:
  • 7 Answers
Your drain line is clogged. Either drefrost the entire unit or use a hair dryer to defrost the drain line in the back of the unit's refrigerator section. Some units have a drain line in the back that is black and needs to be cleared,
Posted on Feb 02, 2010
Ice Diamond model RF68 - what could be causing a small pool of dark brown liquid to collect under the front right hand side of the unit. It has no noticeable smell & dissolves easily in water. The...
Rusty water melting from the drain pan or insulation. Check the condenser is clean, and the drain dan that sits on top of the compressor isn't split.
May 06, 2014 | Freezers
Freezer insulation
Could you fit a trace heater inside the drain tube to keep the ice from forming? Or extend the dripdown time after defrost cycle so the water doesn't accumulate? If the tech thinks the insulation has blown, it may be time to bite the bullet and replace the fridge.
Apr 18, 2014 | Freezers
Ice maker don't work
They are usually located behind the compressor compartment panel. remove the panel and follow the water line you should see the water valve. If there is a water filter in your unit these can plug up ,and cause no water to enter the icemaker. I alo have had bad icemakers.
Mar 25, 2014 | Maytag MFI2269VEW 22.0 Cu. Ft. French-Door...
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Freezer ice making compartment stays in lock mode
the thermostat in the ice machine is not working. its most likely tha the icemaker is a FSP whirlpool it's a lot surer to just replace the hole head and be done with it unless you'd like keep dealing with it.
Mar 18, 2009 | Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Condensation on base of Hotpoint R134a upright freezer
sounds as tho you have an insulation breakdown. no repair except to refoam - and that is difficult to do
Aug 09, 2008 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Freezers Logo
309 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Gerard Curran
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
