Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Its making alot of noise and putting out any
Its making alot of noise and not putting out any water. Another dehumidifier is working great right beside it. The fan is blowing and the filter is clean.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Posted on Apr 16, 2010
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
Dehumidifier seems to not be dehumidifying
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Jun 09, 2008 | DeLonghi Dehumidifiers
My ebac 2000 is making a noise and not collecting water
heatman101
May 23, 2011 | Ebac Dehumidifiers
Should the dehumidifier be blowing air out? It is
Unless the water level sensor is not working and you have the humidity setting low enough to call the fan should be running. If not then check water level sensor or float control to make sure they are working. Make sure the float is free to move if so equipped.If not clean and free up float.I would turn control dial up all the way and see if you can hear it trying to run. Turn it up and down several times.Also if you have a volt meter check to make sure you have incoming power to control and fan motor. Before I spent the money on a new motor I would bypass control and wire straight to motor.Try to isolate problem by process of elimination instead of just replacing parts till you find the right one. I have done this to many times and ended up spending more in parts and alot more in frustration,then the unit was worth to start with. Thank you.
Apr 17, 2011 | Maytag M3DH30B2A Dehumidifier
My dehumidifier is no longer making any noise and is not extracting water. The lights still come on, and when I first plug it in it starts to work for about twenty seconds and then quits. Is this fixable?
heatman101
Apr 04, 2011 | LG LHD45EL Dehumidifier
Dehumidifier makes noise but not working energy star model# LHD45ELY6
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jul 11, 2010 | LG LHD45EL Dehumidifier
When running load noise coming from black cylinder
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Dec 10, 2009 | LG LHD65EBL Dehumidifier
Dem 10 Delonghi Dehumidifier not working
have you tried turning it to a higher setting ??
May 03, 2009 | Dehumidifiers
DH400P
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Jun 15, 2008 | DeLonghi DE400P Dehumidifier
Dehumidifer quit working
Looks like I am in the same boat as all of you. Identical issue with the A7DH45B2A model.
Bad compressor?
Aug 01, 2006 | Fedders R6DH45X Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
420 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
