Error Code CE
I have an LG Washing Machine, model WM-12220FD. I have checked the manual, it says over load in motor, call for service.
How can I fix this myself?
  • Anonymous Mar 15, 2014
    machine is not working, error code ce
    Problem Solver:
  • 9 Answers
Check the fuse and do not unbalance your load capacity.
check motor winding if burn and replace
Posted on Feb 19, 2008
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
LG Washing Machine with CE error code with laundry in the machine and cannot open the door
Problem:
Getting a CE error code
Solution:
This is a *rare* error.
It's highly unlikely the motor is at fault.
Detergent overuse triggers an "LE" error rather than "CE".
UNPLUG THE WASHER...
First--inspect all wiring connections at the MAIN BOARD . If good...
Inspect the wiring at the motor--remove the rear service access panel.
Remove the 17mm bolt at the center of the rotor--this can be tight as threadlocker is used (I use an 18 volt Dewalt Impact drill).
Pull off the round shaped rotor. Use some care--this rotor has magnets lining the inside of it--it's not super fragile but can crack if hit sharply.
Inspect the two plug connections to the motor for loose or frayed wiring. Also inspect the wiring which runs from the base (bottom) of the washer-to-the-motor. Once or twice--I have found wiring frayed from the gyrating tub assembly (repair as needed).
If no obstruction such as a nail or similar object can be seen in the drum (small holes in tub)...if the drum turns freely by hand--the most likely fault will be the MAIN BOARD has failed.
This job is very simple.
Wm2277 service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2012 | LG WM-2277HW Front Load Washer
What Does CE error code mean
LG's 'CE' states 'short circuit to motor or PCB' requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 11, 2011 | LG WM-2277HW Front Load Washer
Code CE pops up and won't continue cycle. What needs to be fixed?
Hello there:
CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited.
further more
If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Oct 03, 2010 | LG WM-2277HW Front Load Washer
Code ce dont turn on
The CE error code is indicative of an over current in the motor. Unplug the power cord, wait for 10 seconds, plug the washer back in, and restart the cycle. If same problem happens again, close the water tap, unplug the unit, and refer to service
Thank You
Sep 12, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
Washer will not spin
you will want to call someone in to take care of it ...its likely the motor is fried
Jan 07, 2009 | LG WM-2032H Front Load Washer
LG Front-Load Washer WM2277HW ce sign
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Jun 07, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer not working with ce showing
Sgt 48
Washing Machines Logo
447 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
