Question about Whirlpool Duet GHW9150P Front Load Washer
F/ll blinking is there a switch in case of flood?
We had 2 inches of water in the basement...got that fixed and now the washer will only blink f/11 is there a switch in case of a flood?
  • 39 Answers
If you had a flood and any water got into bottom of machine, you have probably shorted out a motor control board. These board are either in the lower back right or front left corner bottom. A qualified service tech should be called to do this repair.
Posted on Feb 03, 2010
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
Will not spin or agitate
did the washer cause the flood? you could have got water into the motor if it was above a few inches deep. do you hear the motor working, and no agitator movement? will it fill ? or is it just dead?
Nov 10, 2013 | GE Profile WPRE6100G Top Load Washer
Basement got about 4 inches of water. Washer will turn on, but does not function.
Sounds like the Motor Controller on the left side of this Pic may be the issue. The Drain Pump/Pressure switch is on the left side of the Pic. I feel the drain pump may not work after the basement flood. You can get into Service Mode and try to turn it on from the Console once the machine is dried out.
Aug 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Oasis washer flooded the basement during a wash cycle? How do I fix this?
If the machine doesn't stop filling, it can be one of 2 problems. 1. the inlet valve has jammed open - water will continue to come thro when machine is switched off. 2. the pressure switch has failed. This is located at the top of the machine under the top cover and has a tube about 1/4 inch diameter attached to it, leading down to the drum. As water enters the drum, pressure builds up in this tube & operates the pressure switch turning off the inlet valve. Either the pressure switch is faulty or, more likely, the tube has a hole(maybe tiny) in it and is not allowing the pressure to build up. To test the switch, pull off the tube at the switch. Connect another similar piece of tubing to the switch about a foot long. Switch the machine to start filling. Blow down your new tube to the switch. The pressure you create should switch off the inlet valve while you keep the pressure up. If the water stops coming in, the switch is ok - suspect the tube. If the machine continues to fill, the switch is faulty.
Jun 23, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Ae display warning
Hi
Error AE means that the machine has detected a leak in the base of the washer. The anti flood device has detected the water and its displaying the error AE.
Unplug the washer and remove the back panel of the washer. Check for any stagnant water present in the base of the washer. If no water is present then check for the anti flood sensor and any disconnected wires.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | LG WM-12120BD Front Load All-in-One Washer...
Quiet Partners III will not start. It blinks and then goes off. If I push the "Cancel" pad, it lights 2 and it attempots to drain (no water in tub) and then the light goes to 1 and within a minute it goe...
Sounds like the anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. Nothing else happens until you clear the water problem.
Jan 18, 2010 | Dishwashers
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Flood Damage?
Do error is a Door open error code.. but if it is closed it could be a faulty door lock or a control.. check to see if you can open the door..hope this helps let me know.
Aug 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
131 people viewed this question
Dan Webster
Dan Webster
Sal De
