Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Where does the throttle rod connect to carb? - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
  • 4,234 Answers
3 cylinder perkins gas engine 1960-65 for massey ferguson 135 tractor
Without cranking it, can you take the air filter off and see the throttle plate move as the throttle is moved ?
If someone else cranks it, can you be at the carb and move the carb throttle directly at the carb and control the rpm ?
If so, check your throttle rod for slack, missing spring/connection, something broken.
Sounds like the carb has nothing stopping the throttle from being sucked full open.
Dec 09, 2017 | Cars & Trucks
How to set goveners
As a rule there is a rod that runs from the governor arm to the carb throttle plate arm, sometimes there is a lot of holes to choose from to put that rod into. For most mowing type settings you push the throttle wide open on the carb and push the governor arm all the way full throttle and connect the rod by using whatever hole will let you or bend the rod to get into a hole. Your throttle cable will be connected to the governor arm with a spring ,this will allow the governor arm to swing back and forth to hold a steady RPM that you selected with your throtle cable. In a non mowing application like generators, the voltage output is regulated by the RPM so it would be adjusted by using a voltmeter and setting the governor to get 120 volts 60 cycle at the plug in, In the USA. Without the make and model it is hard to do more then talk theory but if you're handy this info will help.
Apr 07, 2016 | Garden
How do i disconnect the throttle cable from the carburetor so that I can take out the carburetor and clean it.
the throttle cable DOES NOT attach to the carb on that engine. It attaches to the control panel underneath the carb. you have linkage rods that connect and they either have clips or you need to pull the carb mounting studs
Oct 18, 2014 | Husqvarna Garden
Echo throttle cable attachment
pb 255 has a throttle rod and a short cable... so you have a rod that comes off of the trigger and it connects to a short cable that goes to the carb
Aug 27, 2014 | Echo Power Blower PB-255
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
I have a briggs model 407777 that was idling up and down from near top range to bottom. Found some dust in the carb intake and decided to cliean the carb. When removing the manifold/ carb, I took loose...
These can be tricky, but your on the right track. With throttle set on high (engine off), turn governor linkage in the same direction that opens throttle valve in carb wide open, then turn the governor rod in that same direction then tighten bolt on governor arm. This is a static setting. The high and low idle is most likely a dirty carb so assuming the carb is now clean your idle should be better. Hope this helps. Good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 12, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Trigger stuck on full
This machine has a metal throttle rod from the trigger to the carb, you need to look at the side of the carb where the rod connects to the carb, with your finger ( with the engine stopped ) work the carb throttle spindle manually to see if it is moving freely and it springs back to the small throttle idle screw easily, if it does unscrew the idle screw with a cross head screw driver until the machine idles ok, if not you need to take the l/h side cover off to investigate what has happened .
Feb 02, 2013 | Husqvarna Hand Held Blower 125 B Grass...
My husqvarna 455 rancher needs a carburetor kit how do you remove the carb
This is not so easy to explain, this is an X Torque engine so the carb does not come off so easy, there are air tubes on the back of the carb, however, remove the air filter, remove the earth cut out wire and earth return wire from the red switch, they are just push on, there is a blue clip on the throttle shaft side of the carb, gently pull out and twist ( this holds the throttle push rod into the carb ), open the throttle trigger with your finger at the same time now remove the throttle push rod from the throttle shaft, once out of the carb pull the rod toward the front of the saw and out of the tank, now unscrew the four allen headed screws from the air filter housing, and remove, ease the carb up and away far enough to remove the fuel hose, now remove completely.
Feb 18, 2012 | Husqvarna Garden
Governor and Carb spring linkage
the solid wire link goes from the top hole in the governor rod to the carb and the spring goes from the lower hole on the rod to the throttle plate where the cable attaches
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Carb and throttle linkage on a Tecumsen LEV120 361015A
You want the spring to hold tension against the governor.
May 17, 2009 | Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
220 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
