Question about Apple iPod nano
My ipod is lock i forget password - Apple iPod nano
  • 201 Answers
Connect it to your PC, run iTunes, click on the iPod within iTunes, then on the "Restore" button on the right. After restore is done, click on "Sync" to copy music back to iPod.
Posted on Feb 02, 2010
IPod is disabled, and I forgot my password / passcode.
The screen lock is available on the iPod Touch, as well as recent models of the iPod, and iPod nano, allowing you to set a 4-digit passcode to lock the screen. This is to prevent others from using your iPod, but it is not an impregnable security device. If you forget the passcode, you can quickly and simply unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes.
Dec 08, 2013 | Apple iPad 64 GB WiFi
Tip
How do I unlock iPod Screen Lock if you forget your password?
<p>The lock screen on an iPod can be a blessing and a curse. The function does a great job of keeping unauthorized users from snooping in your files, but if you forget the password, it does a great job of poking around you and in your files, too. Forgetting a password is automatically locked iPod into a worthless piece of plastic and circuits, however. You have two options: a quick and painless, and if that fails, the other is slow and clean everything off your iPod ... but you will regain control of the device at the end. <br /> <p><br /> <p>1. Sync your iPod with your main computer, linking the equipment with the supplied USB cable and then open iTunes. Synchronize the two, and open the iPod in some cases. If you do not have access to the main computer - the computer that you used for the initial setup of the iPod to run - you need to restore iPod to factory settings. <br /> <p><br /> <p>2. Connect your iPod to any computer that has iTunes. <br /> <p><br /> <p>3. Open the iTunes software. <br /> <p><br /> <p>4. Click the list to your iPod in "Devices" in the left pane of iTunes. It may take a few moments for the software needed to register the device is connected, so be patient if you do not see in the first place. <br /> <p><br /> <p>5. Click "Restore" in iTunes main window. The first phase of the recovery process takes place; progress can be seen in iTunes. After the first step is completed, iTunes, or instruct you to disconnect the iPod and the battery or asks you to leave it on to complete the process. Do what is asked. <br /> <p><br /> <p>6. Wait for the second phase of the recovery process occurs. This time, the progress bar on the iPod itself. <br /> <p><br /> <p>7. Run the installation process for your iPod after the second phase is completed. The procedure is the same as the first time you sync your iPod. After installation is complete, you'll find the iPod screen lock off<br />
on Jul 21, 2011 | Computers & Internet
Tip
How to unlock the iPod Touch, if you forget the password
<p>The screen lock is available on the iPod Touch, as well as recent models of the iPod and iPod Nano, giving you a 4-digit password to set the screen. This is to prevent others from using your iPod, but it is not a safety device impregnable. If you forget the password, you can quickly and easily unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes. You can then open the iPod and reset the lock to a more memorable password. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer via the USB cable. <br /> <p><br /> <p>2. Wait for iTunes to access and synchronize with your computer. <br /> <p><br /> <p>3. Take your iPod Touch from your computer, clicking on the "Eject" to the input side of the iPod under "Devices" in iTunes. <br /> <p><br /> <p>4. Disconnect the iPod Touch from the USB cable. IPod touch will turn on and will be available. <br /> <p><br /> <p>5. Tap the menu "General" on the iPod Touch. Tap "Passcode Lock and tap either" Turn off access "or" Change. "When you click" Change Password ", you can create a new password. <br />
I forget my password on ipod touch
You can unlock it by simply connecting it to the computer that it was originally loaded from. iTunes will unlock the iPod for you, but it will not reset iPod password. Of course, as long as you don’t need to lock it again, that should be okay. The iPod will not lock automatically — it only does so if you specifically select the “lock screen” option.
There are several hacks and workarounds out there that will supposedly let you clear out the password by editing files in the iPod’s control directories through disk mode access, but I have never been able to consistently reproduce these, particularly on more recent firmware versions.
The only sure-fire way to actually remove the password entirely is to perform a “restore” on your iPod, which will erase everything on it, basically returning it to factory settings. If you’re using automatic sync, however, it should be almost trivial to reload it from iTunes, although it will take a bit of time.
Source:
How to reset iPod Password?
Jul 22, 2010 | Apple iPod touch Second Gen (8 GB,...
Tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
Its locked and it dosnt come up on itunes
I forget the password of my ipod and trying to find it
Dec 28, 2009 | Apple iPod touch
I locked my ipod nano 3rd gen, and i forgot what the password was, is there a way to get back into it?
***** HOW THA ******** GONNA LOCK IT AND THEN FORGET THEE DAYUM PASSWORD LIKE C'MON DAAYUM DUMBEST AS **** EVER AND IF U WNT TO GET BACK IN IT GO TO SOURMATH.COM AND TYPE DA FUCKIN PROBLEM IN !!
Oct 28, 2009 | Apple iPod nano 3rd Generation
My ipod is locked and it the hold switch is not in the locked position. I have restored my ipod and it is still in the locked position. Please help me!
My ipod is locked and i forget the password. I recently sold the computer that my i tunes were loaded into how do i restore my ipod nano.
Feb 22, 2009 | Apple iPod nano
Trouble with combination to screen lock on my ipod nano4gb
To set a password you just move the wheel around to pick a number. Press the center button to go to the next field. If you forget the password you will have to plug your Ipod into Itunes and restore it to factory settings.
Jan 11, 2009 | Apple iPod nano
Apple iPod nano Logo
65 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
