Question about Intel Motherboard
Sata hard disk
I have asrock p4i45gx_pe motherboard.
I want to attach a new sata 160 gb hard disk.
My question is whether my motherboard will support SATA or not!
os: xp_sp2
Ram: 768 mb
  • papai55555 Feb 20, 2008
    hmm thanks for d solution BUT
    my friend who has got a 80gb SATA hard disk
    recently attached his hard drive on my p4p4i45gx_pe motherboard as a primary slave!
    I think SATA works in p4i45gx_pe motherboard
    now when i tried to install that hard drive as primary master
    Sometimes it works sometimes it doesnot works.
    now why is it happenning ?????
    (NOTE:i havnt used any kind of addon pci controller.)
Hi, i have the P4i45GV and it doesn't support Serial ATA.You'll have to buy a IDE hard disk.
Posted on Feb 19, 2008
  • Anonymous Apr 01, 2008
    Hi, the Serial ATA hard drive has a 1cm width data cable generally of red colour and fits in a small plastic connector, the actual devices doesn't have the capability of setting master and slave drives on the same channel so, you probably have a IDE hard disk with a +/- 5cm wide data cable and 40 or 80 wires between the connectors.
    The ASRock p4i45 motherboard fully supports up to 4 IDE devices on it's 2 IDE connectors.
    Look at this picture
    The upper connector is a IDE Interface connector, the other with a smallest red cable is a Serial ATA (or SATA) connector.
  • Intel Master
  • 13,433 Answers
As far as I know and saw from asrocks website your motherboard does NOT have a SATA connector so the installation wont be possible without buying a addon pci sata controller card witch is around 10-30 usd or 10-20euro.
good luck and if there is anything else let me know.
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
Maximum hard disk capacity for asrock p4i45gv board
Unlimited. The only limit you could encounter is the 2 GB limit on file size when you are using the FAT file system - like in memory cards.
Apr 24, 2010 | Asrock P4I45GV...
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
P4VM800 SATA HDD Problem Plz Help me!!!
Your P4VM800 won't detect a SATA II (3 GB/s) drive, only a SATA I (1.5 GB/s). You basically have 2 options:
1. if you have a friend or colleague with a machine that supports SATA II, install the disk in that machine and us the manufacturer's utility to set the SATA to 1.5 GB/s (Seagate/Maxtor disks, but only these do have a jumper to do the job but SATA is in other respects jumperless). Then you can reinstall the disk in your machine.
2. Buy a host adapter card for SATA II and install it in a free slot in your machine - but may be better to put the money towards a new motherboard.
Oct 17, 2008 | Asrock 775Dual-880 Pro Motherboard
Can't install Hard Drive MS Server 2003
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
http://down3.driversdown.com/Bios/ich5r_6300esb_ich6r_msft_raid.exe
ICH6/7/8 Sata Raid drivers
http://down3.driversdown.com/Mainboard/iata621_cd.exe
ICH9
http://downloadmirror.intel.com/14849/eng/f6flpy32.zip
Please tell me if u need anything else.....
Regards,
Siddesh Prabhu
Aug 30, 2008 | Intel Motherboard
Does Asrock P4VM8 support 500GB SATA hard disks?
near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
Jun 23, 2008 | Asrock P4VM8 Motherboard
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
For installation of sata h. drive
ad8d69d.jpgif u can open the cpu cabinet, check on the motherboard if u have a slot as shown in the left picture.. if it has, then u can connect the sata hard disk. if not ur motherboard only has ide connectivity.
May 15, 2008 | Intel Motherboard
Intel Motherboard Logo
193 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
