Question about Sony PlayStation Portable (PSP) Console
Damaged psp left overnight in small puddle of water will not work at all. Will i have to replace it?
    Problem Solver:
  • 35 Answers
Hi There mum2sort
That nasty problem you got there could be any number of problems could be Buggered Motherboard could be buggered Lcd Screen Cant really say unless looked at best solution "Electrician" might be able to give the board and lcd a test that be the best way for surely then you will forsurely find out :) hope this helps and please if you have the time rate me
thanks
Posted on Feb 19, 2008
Water puddling under front/door. Still cold but cant find settings info and concerned seal has gone and housing will be damaged. Less than 6 months old
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 25, 2015 | Refrigerators
I have an artic king freezer model arco7mw and it has puddles of waterneath,why is that?
Freezer /fridge water/ice in fridge and or freezer
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Mar 02, 2015 | Refrigerators
Every few days I find a small puddle of water near the front left corner under the freezer of my TFH22JR.
Guys, . . . small puddle of water on the FRONT left side?? Y'know, . . under the FREEZER door??!? Maybe check the John Guest quick connect/disconnect fitting at the bottom of the freezer door just behind the front cover. It may not be fully connected, or may have a seal worn-out.
Apr 12, 2014 | GE Refrigerators
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
My psp recently fell into a puddle of water and its directional arrows have stopped functioning .
Other parts of your PSP might soon stop functioning, because of the cause of it being in a-lot of contact with water... Best thing to do atm... is to bring your PSP to repairs.
SONY is one, but you can find other smaller electricial appliance repairers; technicians that are usually cheaper!
Nov 08, 2009 | Sony PlayStation Portable (PSP) Console
Small puddle of water won't drain
make shure the strainer is clean
there could be a partial blockage in the pipe
make shure the drain pipe isnt kinked
Mar 18, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Small puddle of water from dryer?
you should check the back vent on your wall have you had any rain lately some times the strong rain will go down the back wall in the vent if broken
Jan 30, 2009 | GE WDSR2080D Top Load Washer
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Sony PlayStation Portable (PSP) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
