Question about Epson Stylus Photo 1290 InkJet Printer
Green and red lights on solidly, error message saying 'cartridge not recognized' even when it is a brand new Epson cartridge! Tried a reset but it doesn't make any difference
    Novelist:
  • 157 Answers
When you installed the cartridge, did you check for any protective tape on the cartridge at the bottom. This is a common missed item in the installation process. If there is tape on it, check instructions and remove it. The cartridge will not work otherwise.
Posted on Feb 02, 2010
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Magenta cannot be recognized red light keeps on blinking even after i reset
HAve you tried other MAgentas? if so and same error the contacts in the printer are dirty or broken- What model?IF changing ink clears the problem- it's dirty contacts (the green chip with gold spots- clean with alcohol OR it's bad ink. If it's a "bad" epson brand cartridge, they'll replace it (sometimes not worth the effort).If it's a bad anything else (chinese refil, etc) throw it out and lesson learned
Sep 04, 2012 | Epson Office Equipment & Supplies
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Replaced a new cyan cartridge for Epson 1400. Printer ignored it.
Ye of course it could be faulty and Epsons are sometimes very fussy about using third party carts. Get it replaced at your store, try a different brand or buy a genuine Epson cart if you can afford it.
Jul 04, 2009 | Epson Stylus 1400 InkJet Photo Printer
Printer won't print
Hi
try running a selftest to determine that you are not having issues with the printer itself. make sure there no red light or onl;y green solid light shows on the panel then try reprinting,
keep us posted
Jan 11, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson CX 5400 won't recognize off brand magenta cartridge
Yes replace the possibly faulty cartridge as some just don't work. If you take it back to where you bought it from they may replace it with annother one free of charge?
Hope this helps....
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Stylus Photo R280
Ink carts being not recognized and you say its a brand new printer?
Heres what you may want to try.
1. Turn off the printer and disconnect the usb cable from the printer
2. Press and release the ink button once you see a solid green light and solid red ink light
3. Open up the printer cover and check out where is the ink cart holder positioned
4. It should stop in the middle part of the printer, you should see an arrow or a ink out marker (ink icon with a / with it( indicating which ink cart is out or not recognized or expended. (This is a usual process on all the epson stylus photo series I had)
5. Press and release the ink button again, it should stop to the next ink cart which you are having a problem and if it doesnt then your ready to reclamp the ink carts.
Just follow your manual usually theres an on screen instructions how to manually replace or reseat the ink cartridges. If the issue persist, you may want to contact epson, ask for a warranty procedure or what you can do next for this. (Either a bad set of ink cart or a bad print head) Good luck!
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R200 - Solid Red Light and printer not working
printer cartridge chnaged again red light pinking not printing pls give me solution
Jan 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
