Two of the memory slots in my computer destroy DMMs as soon as the power is applied.
  • joecoolvette
    joecoolvette May 11, 2010
    Out of curiosity what motherboard, or computer is it? (Computer name, Model Name. and Model Number) Also what ram manufacturer name, model number, and type of ram memory. (Manufacturer name: Corsair, Kingston, OCZ, and so on. Type: DDR Sdram, DDR2 Sdram, and so on)
    Novelist:
  • 157 Answers
You have three options:
1. Don't use those slots and even cover them with electrical tape so you don't forget.
2. Get the board replaced or repaired
3. Return the computer to the store where you bought it and get another one. The manufacturer of the computer may also warrant it and replace the computer.
Posted on Feb 02, 2010
Install ram upgrade for acer aspire 5310 pc
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase or buy for working pairs if possible
Unplug your laptop from the AC power source and remove the battery.
Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
Locate the memory access door for the main memory module. It should be on the back of your computer.
Unscrew the memory access door and remove it.
Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
Align the new RAM module with the tab in the connector slot.
Slide it firmly into place and gently rotate it downward until it clicks into place.
Replace the memory access door.
Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use.
hope this helps
Aug 22, 2012 | Acer ASPIRE 5310 COMPATIBLE LAPTOP LCD...
Power but no cpu
First check the processor fan is working if working remove the memory from the slot clean with a clean cloth and rub the conector with a erasor dont use any metel or any other thing insert the memory and see if the lock is locked on to memory properly still not working change the memory sutable for the memory slot still not working removce the processor heatsink and the processor clean the surface and apply athin layer of heat sink compound and fix back the processor if still not working change the processor if still not working use an addon graphics card and check for display
Aug 23, 2011 | Intel Computers & Internet
How do I install memory in my acer d722-bz197?
  • 1Unplug your laptop from the AC power source and remove the battery.2Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.3Locate the memory accessdoor for the main memory module. It should be on the back of your computer.4Unscrew the memory access door and remove it.5Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.6Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.7Align the new RAM module with the tab in the connector slot.8Slide it firmly into place and gently rotate it downward until it clicks into place.9Replace the memory access door.10Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use
  • Aug 15, 2011 | Computers & Internet
    My lcd monitor AL1717 has initial blinkig &there is no display,after some times it works properly,what is problem.
    Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
    Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
    If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
    If you still not hear the beeps then change the processor
    If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
    Apr 01, 2011 | Acer AL1717 17" LCD Monitor
    In display showing no signal where would be the problem or how to check and analyse the exact problem please tell me
    Apr 01, 2011 | ASUS P5PE-VM Motherboard
    Netvista does not boot up after replacing with 2 gb of new memory
    Hi !
    I just not well placed and fitted. Turn off your computer and remove all the power cable connections. Remove again memory chips and return tightly fitted into the slot. Something it will not reboot our computer when it is not well fitted into the slot. It happen to me before that I cleaned the CPU unit and suddenly it would not open the computer. I disassemble all and found out that the problem it the memory chip that is not fitted correctly. Just repeat the insertion and soon it will boot up your computer.
    I hope it helps you and thank you for using FixYa !
    Jan 08, 2011 | IBM NetVista PC Desktop
    Pc doesn't start properly, and displays a 1 & 3 on the front panel
    Memory modules are detected, but a memory configuration or compatibility error exists.
    May 11, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
    Laptop loses power and shuts down for no reason.battery is dead and theres no back up power
    • use a power cord - if the problem persist..--if it works then it is the battery that needs replacement; or else
    • try to reseat the memory, try to switch the memory on its slots (if there are multiple slots) - it could be the memory
    • if it comes to the point of no power at all after the above steps then it is the system board.
    Apr 28, 2009 | Computers & Internet
    Sata Hard disk and DDR 1Gb Ram not supporting to my motherboard how can i add and detects this both things please give me reply as soon as possible
    Do you have a SATA Cable for your SATA hard disk?
    What are the spec's for your RAM, it should be 2 x 184 pin DMMs, 400 MHz, 333 MHz,266 MHz memory. up to 2 GB Ram.
    Jan 23, 2009 | Mercury KVM800M Motherboard
    Dell Inspiron 600m not starting up!
    I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
    Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
    Solution:
    You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
    If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
    If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
    Jan 02, 2009 | Dell Inspiron 600M Notebook
    Computers & Internet Logo
    20 people viewed this question
    David Payne
    David Payne
