Replace brushes in an indisit washing machine
Where are the brushes and how do i replace them in an indisit wg1130t washing machine please?
  • Washing Mach... Master
  • 3,463 Answers
Remove the rear panel of washer.
Remove belt from motor, unplug lead to motor, remove earth wire.
Undo screws securing motor, and remove motor.
The brushes are located at the opposite end to the motor pulley, you will see a wire going to each brush.
Please rate my solution.
Thankyou
Posted on Feb 02, 2010
The lock on the door has broken how much is a replacement
Hi Janine, door locks don't cost a lot I have had to buy one a year ago it only cost me £8-00 i fitted it it was easy,but again it depends on the washing machine type mine was an Indisit and it again depends on if you are fitting it or you are getting a washing technician in.
good luck
Mar 01, 2015 | Washing Machines
Hi. I have an Indisit Washing Machine IWDC6125 The fault is that the power light does not illuminate. Power to the machine. Thought it was the door latch switch, replace it but. Still have the. Same fault....
Good probability the carbon brushes in the motor will be very low .before initiating a cycle the on board diagnostic runs a quick test on the appliance components .if it detects no circuit over the com ie brushes low it immediately goes into fault mode and won't start
Feb 16, 2014 | Indesit Washing Machines
Replaced beko motor brushes on washing machine and they are making funny noise
Please remove and reset the brushes are it could be out of alignment , Please check this link for tips: Brush setting
Feb 01, 2013 | Washing Machines
Drum not spinning on my indisit dryer
If the dryer has a belt fitted it may have come off or snapped, remove the lid or look underneath and you may see a broken belt.
If not belt driven the brushes in the motor may need replacing if they ahve worn.
Dec 29, 2012 | Dryers
What are the official dimensions of an indesit wg1130t
These are the official manufacturer specified dimensions for the WG1130T
width 59.5cm / 595mm / 23.42 inches
height cm 85cm / 850mm / 33.46 inches
depth (front to wall) 55cm / 550mm / 21.65 inches
If you need any further specicications, please post back or download the full user manual from here:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WG1030G_WG1130TG_WG1230G_19502233000.pdf
Regards,
BElectric
Nov 28, 2010 | Indesit W 123 Front Load Washer
Fault code h20 flashing on indisit wie127 washing machine
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Thankyou.
Jan 21, 2010 | Indesit W 123 Front Load Washer
Washing Machine door locked with flashing red light above on/off button, the model is a Indisit WD12X, there no water in machine and pump is cleaned with no obstuction. can anyone help with this problem
Try turning off the machine at the plug for about 10 minutes or until the light on the machine disappears, then try to open the door.
Usually works for me.
Regards jonno
Apr 04, 2009 | Washing Machines
Indesit Wg1130T
DRAIN PUMP BLOCKED OR FAULTY
Oct 25, 2008 | Indesit W 123 Front Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
