My NDS Lite bought 3 days ago turned off. Now it won't turn on. When I input the charger the red light appears. But it doesn't blink like in those fuse tutorials. It is still. What can cause this? Thank you.
I don't think so, because there was no warning that console is going to shut down. =(I don't think so, because there was no warning that console is going to shut down. =(
You can't post conmments that contain an email address.
try removing the battery. Then plug the charger in and see if if ti turns on. if it does that means your battery may have gone bad. if it still does not turn on the charger or the DS may have gone bad :/ hope this helps :)
The problem is that your son dropped it. This damages both the inside and outside of the DS. I would suggest contacting your nearest video game store to see if they can fix it.
The NDS enters the sleep mode abruptly
1.It is possible that external magnetism causes the system to enter in sleep mode .Therefore ,keep the system away from nearby magnetic objects
i had same problem ( bought a faulty nds off ebay and would charge but nothing when powering up, not even a blink of green light) problem is a component called a L2 its an inductor 33uH in case SMD 1007. its situated dirrectly under the power switch but they are prone to fall off when nds is dropped ect. you need to resolder it on (very tricky). give your nds a shake to see if you can hear it rattelling about. be carefull when opening your nds not to lose the part (its very small, about 4mm long 2mm wide) GOOD LUCK
I have a NDS as well and know it can be tricky. If you e-mail me at [email protected] I Might beable to fix your problem by asking some questions. try plugging it in to the charger and starting it.
