Question about Refrigerators
My Whirlpool WBM35LW refrigerator now beeps intermitantly even when the door is closed. This is very annoying.
    Problem Solver:
  • 8 Answers
Check that door switch is working correctly . positioned on cabinate not on door . even if it looks OK it may not be working . check freezer fan is working correctly. If they both work then check thermostat / temp control switch and control board. All in that order . cheers .
Posted on Feb 03, 2015
Throw it out and don't buy Whirlpool again. I had the same fridge and it was doing the same thing and would of cost heaps to fix it.
Posted on Oct 29, 2010
What would cause a very faint intermittent beep on Whirlpool refrigerator? Not all of the time. Everything works great on it. It's brand new. Beep is bugging me though.
Hi,its not like the sound when you leave the door open on the fridge door,if you are not shore try leaving the door open for a fuw momments to see if it sounds the same.
Just a thought,I hope you get it fixed it would iritate me as well.
Jun 10, 2015 | Whirlpool Refrigerators
Whirlpool refrigerator model# gs6nhaxvk 06...fridge and freezer works normal, but water dispenser and lights not working and the door ajar alarm is beeps.Please advise.
if your freezer door is not closing properly you will have problem with the dispenser because the light switch activate the dispenser is a safety device checked why your door is staying ajar. can be gasket or what i have seen is that after cleaning the refrigerator the customer don't put shelves in properly causing shelf to push against door
Dec 20, 2014 | Whirlpool Refrigerators
Why is the fridge beeping as if it was still opened although it's closed ?
Door sensor is either stuck or a door is not shut properly check the door hinges then unplug for 5 minutes to rest the board it should stop.
May 09, 2014 | Whirlpool GI6FARXXy French Door...
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
My fridge does the open door beep and motor on/off just by opening the door. Ive searched through here and suggestion is to clean the door switch, but I cant find the door switch on freezer or fridge...
Depending on which two numbers after the ET1FHTXM may make a difference. For example ET1FHTXM00 the only thing that may cause a beep or cut the refrigerator (that I know of) on or off would be=> Circuit Board or Timer 2213473 This is a ADC adaptive defrost control and when they go bad strange things happen.Click Here=>
Whirlpool ET1FHTXMQ01 parts manual.pdf
You can also find a Tech Sheet wiring diagram=> Here
Thanks, Sea Breeze
Jan 26, 2011 | Whirlpool ET1FHTXM Top Freezer...
My whirlpool refrigerator beeps continuosly when i open the door, the light flashers also & the motor sounds like it stops & starts also. What is the problem?
Hello All.
I would like to add my findings.
My fridge WBM46LS of 11 years started behaving exactly as the OP described. I tried all the suggestions regarding holding buttons, power off etc to no avail.
I even found an online manual here
https://www.yumpu.com/en/document/view/18647891/whirlpool-uk-refrigerator-models-wbm35lw-wbm35ls-/5
But that did not address the problem at all.
So I went back to someones suggestion about the Potency Module.
I pulled the fridge out and unscrewed the cover at the bottom left to get access to the Potency module.(Red plastic box)
Without even pulling it open I could smell the burnt electronics.
I opened up the case and found a scorch mark next to the big capacitor on the circuit board.
So far, so good.
Given that a new fridge of the same size/style is about $1300 I pursued the spare part.
I then tracked down a supplier in Melbourne with a new board/module for $148.50. P# WPP326020913
Plugged in the new board in and fired up the fridge and its working just like new.
So I am happy now that a perfectly good fridge is up and working again.
Dec 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Whirlpool fridge WBM46LW top freezer that the alarms beeps, light flashes and motor cuts in & out when door opens or sometimes after a few seconds with door open.
Hello All.
My fridge of 11 years started behaving exactly as the OP described. I tried all the suggestions regarding holding buttons, power off etc to no avail.
So far, so good.
Jul 28, 2010 | Whirlpool Refrigerators
When fridge/freezer door is opened the fridge starts beeping and the light constantly turns on and off until the door is closed
WHEN i OPEN MY WHIRLPOOL FRIDGE THE LIGHT FLASHES ON AND OFF AND THE COMPRESSOR APPEARS TO CUT IN AND OUT AND THE FRIDGE BEEPS UNTIL DOOR IS CLOSED. cAN ANYONE HELP?
May 23, 2010 | Whirlpool Refrigerators
Refrigerators Logo
1,079 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
