hina phones are possible to have gprs connection or internet connection.. i made it in my own phone (china)
but in trying to change the themes of your phone.. my dear, it's impossible cause it's the default feature of all china phones.. you cant put other themes except to their default themes.. :)
but once i got the solution in our prob. (which is trying to change themes of a china phone)]\
OR:' On the real 6300 you have to go to Main Menu > settings > themes. On the chinese clone the settings should be almost the same too. Hope this helps. OR you might also want to refer to the manual you got with the phone.
Download Sony Ericsson Theme Creator, change phone type to K850, create or edit you downloaded themes, when your done with changes, click on XML Editor [XML] on the toolbar, check the xml codes for the version(usually on top), change it to your spiro's theme version(K850 settings is for 4.6.3 version like mine), click 'Apply' then 'Ok'. Click 'Save as..' , edit the theme's name as you want and now you can use the theme.
[To check your theme version, copy one of the preloaded themes to your memory card, then when connected to PC, copy it to your desktop, open it using Sony Ericsson Theme Creator, it'll pop a permission to change it to latest version, don't click 'Ok' yet, check current theme version(mine's 4.6.3).]
Refer to http://bit.ly/gOCak4 for theme versions and set the phone type according to your theme version (4.7, 4.5 etc)
Go to the menu of your phone, select the settings, select the display option, then you select the theme from the display option, then select your choice theme from there.
china phones are possible to have gprs connection or internet connection.. i made it in my own phone (china)
OR:'
our main problem is the OS installed...so we have to know where and how we can replace the OS installed in our china phones...i'll post here immediately once i get a solution.
For changing themes in 6233 phone memory equla to size of theme should be free. For ex. - if theme size is 215kb then phone memory should also have 215 kb free space . Free some space in phone memory and then try.
thank you
