Question about Dell Latitude D600 Notebook
Dell Axim X30 System Update for Windows
Where do I find Dell Axim X30 System Update for Windows ?
  • Dell Master
  • 19,396 Answers
How do you install downloaded programs on the Dell Axim X30?
Downloaded programs can be installed onto the Dell Axim X30 using Microsoft ActiveSync. Microsoft ActiveSync can be installed onto your computer using the Dell Companion CD which came with your Axim X30.
Once Microsoft ActiveSync is set up on your computer, if the program you downloaded came in an installer file, then double-clicking on the file will start the installation wizard and the software will be automatically transferred to the Axim.
If the program you downloaded did not come as an installer file, then double-clicking it will bring up an error message. In that case, use ActiveSync Explore to copy the program file to the Program Files folder on your Axim.
Mar 05, 2011 | Dell Axim X30 Pocket PC
Is my Axim X30 compatible with MS Office 2007?
If you save the document in word 97/2000 it should work with the X30 version of word.
Aug 14, 2009 | Dell Axim X3 Pocket PC
I have an Axim x30 and I am in the process of flashing the bios. Everything went well until it started to copy the new bios to the device. The message came up "lost usb data stream". Now there is no usb...
May i direct you to this site : http://www.pocketpccentral.net/help/dellx3reset.htm
It shows how to soft reset and hard reset your Axim. I believe that after a hard reset your axim shall sync and you should try updating the rom again.
I take it you were using a rom update from Dell?
Best Wishes
Karlos
Jun 28, 2009 | Dell Axim X30 Pocket PC
Can't browse in my internet explorer
Hmmm.. try downloading this and running it:
http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R101483&formatcnt=1&libid=0&fileid=131500
its a system update for your pocket pc, supposedly it will fix any issues you have. Also you may want to check your router and make sure your axim is allowed on this list of IPs.
ALSO make sure the "enable" switch is turned on, on the right lower bottom of the device.
May 27, 2009 | Dell Axim X30 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Lost CD Rom for my Axim x30. Anywhere I can download it?
You need ActiveSync from Microsoft. Unless you're using Vista which uses Windows Mobile Device Center. Connecting to the Axim to a Vista machine should automatically download the Windows Mobile Device Center software.
ActiveSync for XP and older systems can be downloaded here:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
You'll proabbly still want to update your Axim's firmware and drivers if possible.
Feb 04, 2009 | Dell Axim X30 Pocket PC
OLD AXIM 30, NEW DESKTOP COMPUTER RUNNING VISTA
Everything you need should be in the Vista native Synch center
http://www.microsoft.com/windows/windows-vista/features/sync-center.aspx?tabid=1&catid=1
Jan 03, 2009 | Dell Axim X30 Pocket PC
Dell axim x30
HI You have two ways: 1) Install the ActiveSync (Version 4.2 is recommended) PC Software with your PC first Next, you connect your Axim to your PC. Then you install the software or game into your PC. it will also install into your Axim automatically thru Sync process. 2) Or install the software or games into your External SD Memory card thru USB SD Card reader. Then put your sd memory card into your Axim and run the software or game. The 2GB or 4GB SD Card is reccommended since the game or software sometime is huge. I hope it is help. Regards, pingping
Jun 14, 2007 | Dell Axim X30 Pocket PC
Dell Latitude D600 Notebook Logo
56 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
