Question about Wesco Manufacturing Hydraulic Raise-N-Roll Machinery Dolly 6000 Lb. Capacity - Pair
Wesco Mft Model # PL-54-2222-3W219 Leaking hydraulic fluid and will not lift need rebuild kit for complete hydraulic system.
2 Suggested Answers
SOURCE: Wesco Hydraulic platform lift needs pump valve re-assembled.
Go to: www.wescomfg.com/instructions/pedalift_seal_kit_with_pricing.pdf
Posted on Feb 24, 2011
How do I add hydraukic fluid?
There is a rubber plug on the side of the ram which comes out fill to the level of the hole using jack oil .
Apr 03, 2015 | Wesco Manufacturing Wesco Hydraulic...
Can you repair hydraulic lifts by adding fluid? Sunstar ZX30 3F Wolff System tanning bed.
I don't think these would have a "user refill point". I would suggest taking one off and take it to a cylinder rebuilder. If they can't do it then it will have to be replaced. Someone that rebuilds hydraulic cylinders would be a farm implement service shop.
Sep 22, 2014 | Health & Beauty
How to change seals on a wesco pl-54-2230 hydraulic jack
This is a hi-tech job best left to an hydraulic pro for safety reasons.
Jul 12, 2014 | Wesco Steel Hydraulic Pedalift 2 Wheel...
Need service manual for wesco DPL-54 hydralic lift
http://www.wescomfg.com/html/contact_us.htm
Wesco Industrial Products, Inc.
1250 Welsh Rd
North Wales, PA 19454
P. 215-699-7031
F. 1-800-346-5511
Jun 09, 2012 | Wesco Manufacturing Wesco 518X Head Chef...
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Need a rebuild kit for the hydraulic cylinder that lifts the snowblower - does such a kit exist and what is the part number?
there are rebuild kits for some but not all, check your local jd dealer, my family ownd a jd dealer until last year jd stuff aint cheap. personally id type hydraulic cylinders into google and buy a replacement
Nov 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Ford 770A loader hydraulics lift cylinder shaft won't move.
Hello there:
when you dissconnected the hoses did you turn the cylinder upside down and let it drain cause some hydraulic lift assybelies have a small chamber in the head of them that retain fluid and with out removing the fluid it will do a hydraulic lock and wont be able to move untill you losen the bleeder screw if it has one ok please let me know how this goes for you
Sep 10, 2009 | Garden
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
Jan 04, 2009 | 1989 Ford Mustang
Drill problem
Heating of hydraulic fluid in operation is caused by inefficiencies. Inefficiencies result in losses of input power, which are converted to heat. A hydraulic system's heat load is equal to the total power lost (PL) through inefficiencies and can be expressed as: PLtotal = PLpump + PLvalves + PLplumbing + PLactuators If the total input power lost to heat is greater than the heat dissipated, the hydraulic system will eventually overheat.
Aug 27, 2008 | Bosch PC11PCM Power Change BiMetal Master...
Wesco Manufacturing Hydraulic Raise-N-Roll Machinery Dolly 6000 Lb. Capacity - Pair Logo
842 people viewed this question
Top Wesco Manufacturing Welding Tools Experts
Bill Boyd
Are you a Wesco Manufacturing Welding Tool Expert? Answer questions, earn points and help others
