Question about Air Tools & Compressors
My Ingersoll Rand 185 starts but does not have air at all. Just idles.
    Champion:
  • 243 Answers
Make sure that screw is running. check connections to loadbutton if there is a thermostat for warm up you can try to bridge this also check solenoidvalve for load-unload.
Posted on Feb 07, 2010
Air compressor starts and builds air then idles and when it goes to rebuild air it dies
if your saying it wont recover from idle down mode back to full speed , this might be the IR fuel pump/regulator problem (a pressure gauge will need to be added to verify this ) , if so save your money go with an aftermarket pump it'll last longer
Mar 25, 2014 | Ingersoll Rand Air Tools & Compressors
Where is oil cooler
Hi not totally familiar with this compressor but the oil cooler will be in front of the air intake vents with the cooling fan behind it
Mar 07, 2014 | Ingersoll Rand P185WJD Platinum Series Air...
I have a 175 pull behind IR compressor. When trying to set the high Idle I open the valve so that it is reading 100psi, the motor trys to throtle up but it seems under to much of a load. also when it drops...
100 psi is around the pressure that the engine goes back to idle
it should start to go to fast rpm when the pressure drops to around 75 psi
if it is trying to increase rpm at 100 psi , the engine is under load and that is your problem
Dec 19, 2017 | Ingersoll Rand P185WJD Platinum Series Air...
Throwing out oil at ingersollrand air compressor
Need more info . Where does oil appear to be coming from. what's the model and serial #.
Nov 17, 2011 | Ingersoll Rand Rotary Screw Compressor ...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Need to know what compressor oil to use for 185 ingersoll rand compressor
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Oct 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
294 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
