Question about Kitchen Ranges
Where can I buy the vent top on Roper FES310BW1 oven
Where can I buy the vent top on FES310BW1 oven door. this is the metal part on the top of the oven door that the handle bolts on to. It fits down over the top and extends down both sides approx 3 inches, on the top of the oven door. It also appears to have a vent in it, and the latch locks into it. (It is a self-cleaning oven).
  • 619 Answers
Sorry to tell you but just checked all sources available and this part has been discontinued. The part # is 3169515 if you find someone who says they have make sure they are able to lay their hands on it at that time. Sorry couldn't be more help.
Posted on Feb 03, 2010
Testimonial: "altho it's not what I wanted to hear, it still lets me know where I stand, and the answer was quick. thanks a mi"
I can't figure out how to get my older roper microwave off the wall
If there is a grill above the door, remove it. There will be two long screws that attach the unit to a metal plate. The metal plate is bolted to the wall. Once you loosen the long screws, the unit will tilt down and come off the wall.
Jan 15, 2014 | Roper Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
We were using a Roper range last night Model F990880 or F9908B0 (hard to read). It started beeping and flashing F2 and F3. We can't find a manual and are wondering what it means and how to fix it.
The oven temperature sensor has failed.
Turn off power to the oven.
Open the oven door.
Look on the rear wall of the oven up high for a thin metal piece extending into the oven.
Remove the screw and pull it out.
Unhook the quick connect wire harness.
Buy a new temperature sensor and reverse the order above to install.
Jun 27, 2010 | Roper Kitchen Ranges
Need to buy oven seal strips, vinyl slipped over metal
Hi, Look for the model # around the door, pan drawer, or lift the top and see if there is a tag there.
Jul 22, 2009 | Ovens
Cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Feb 04, 2009 | Ovens
Seems like it may be overheating.
check also, the fan. there may be lint built up inside the fan blades or housing blocking air flow
not a solution, yet, something to check
Jul 25, 2008 | Roper REX4634KQ Electric Dryer
Roper Double Wall Oven
hi,
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Mar 22, 2008 | Microwave Ovens
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
